Posts: 536 from 2012/4/28
Kronos escribi�:
You probraly hadn't MorphOS on the 1st partition, follow the instructions at the end of the dualboot.pdf to get back to working settings.
While in OF you can eject the CD, not sure wether it was "cd eject" or "eject cd".
Yes I have installed MorphOS in the first partition, I think that problem perhaps for the PRAM from the MacMini and it was crashed with the last change in the MacMini world the new LCD Monitor that I bought, I read that the MacMini saves in the PRAM the changes of volume, screen size, etc., and perhaps this is the problem, but how I can resurrect the Mac?
