New native MorphOS powerUp drivers for G-Rex!
    Crumb
    Posts: 736 from 2003/2/24
    Frank Mariak has uploaded a new web page for G-Rex
    ATM the webpage includes native drivers for the RTL8029 driver.
    He plans to release native MorphOS G-Rex soundcard drivers in the future too, so Terratec 512 users may be lucky.
    He accepts donations, so G-Rex users can show their support.
    He also has included in the webpage a native MorphOS AriadneII driver.
    Thank you Frank!
  • »30.11.06 - 09:23
    Posts: 109 from 2006/9/10
    If there would be only some G-Rex available somewhere...
  • »30.11.06 - 09:38
    analogkid
    Posts: 685 from 2004/11/3
    great news for GRex users ! Will there come Sound- and USB-drivers, too?
  • »30.11.06 - 12:25
    Amigaz
    Posts: 121 from 2005/6/11
    Great news
    Now I need to track down a G-rex :D
    But still no way to reg MOS PUP which is a disaster *whining*
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »30.11.06 - 13:37
    hooligan
    Posts: 1948 from 2003/2/23
    @Amigaz
    Check out the fleamarket-forum.. an early xmas gift awaits you ;-)
  • »01.12.06 - 04:18
    Amigaz
    hooligan wrote:
    @Amigaz
    Hope I'm not too late :-(
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »01.12.06 - 05:39
    DJBase
    Posts: 745 from 2003/4/6
    The RTL8029 seems to be the old 68k 'cause it has exactly the same file size.
  • »03.12.06 - 14:36
    Amigaz
    A native X-surf driver wouldn't be wrong either ;-)
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »04.12.06 - 20:57
    Posts: 537 from 2003/4/11
    At least sound drivers if time permits ...
    Unfortunately, USB drivers only have limited use with G-REX. This is basically due to a bug in the CSPPC/BPPC DMA interface which fails on small data transfers (which are required for certain kind of usb transfers). I have a fixed CSPPC which has an updated firmware that fixes this bug but this version never made it into public and would require an in-circuit reprogramming of some components. DCE bought out phase5's CSPCC/BPPC business and they stopped supporting any Amiga stuff quite a while a go afaik, so there is not even a chance to get boards updated. So to make a long story short: USB drivers won't work with G-REX.
    bye
    Frank
  • »05.12.06 - 18:45
    Amigaz
    hooligan wrote:
    @Amigaz
    Too bad he only prioritized german speaking buyers :-o
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »12.12.06 - 21:04
    Amigaz
    Anyone know if the Ariadne driver works on the plain Ariadne card?
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »12.12.06 - 21:06
    Amigaz
    ^BUMP^
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »14.12.06 - 08:03
    Golem
    Posts: 766 from 2003/2/28
    I doubt it'll work seeing as the original ariadne is based on a different chip.
  • »14.12.06 - 08:31
    Amigaz
    Anyone tried the Ariadne driver?
    My CPU load is at constant 99% with it :-?
    Switched back to my X-surf II again
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »18.12.06 - 20:27
    Sir_Lucas
    Posts: 112 from 2006/4/23
    I've recently tried the new ariadne driver and I have the same problem as you.
    Cpu overload, it shows 99% and after a while it freezes. Any ideas as where to start or look?
  • »26.04.07 - 07:41
    CLS2086
    Posts: 168 from 2005/8/25
    Any chance to get a MOS PUP driver release for the ESS solo1 sound chipset ?
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too :-)
  • »26.04.07 - 19:10
    Crumb
    GREX RTL8029 driver works fine with my Prometheus :-)
  • »28.04.07 - 12:50
    Since prometheus uses the same pci abstraction within MorphOS, it might of course as well work with GREX drivers but it can't actually be guaranteed to work .....
    bye
    Frank
  • »29.04.07 - 11:51
    I just uploaded Terratec 512i Fortemedia801 drivers to the grex page. You might better get hold of one of this cards for GREX, it's DMA capable opposed to Solo1 and causes less CPU load. I might consider porting the ESS Solo1 driver as well, though ....
    bye
    Frank
  • »29.04.07 - 11:53
    Posts: 236 from 2003/7/28
    bye
    Frank
    I can't get the rtl8029pci.device.elf to work on my GREX/MorphOS powerup system. Miami says unable to open unit 0. In snoopdos it reads the file OK and it's in devs:networks ....
    I did get the FM801 driver to work but the audio quality isn't as good it seems as the 68k driver. I didn't do much tweaking other than set Music Unit to 44 or 48khz and Unit 0 as well.
  • »23.04.23 - 16:49
    Posts: 891 from 2003/3/4
    Tried a different stack? Miami was quite odd about how it treated network *.device drivers.
    Way waaaay back in the 90s I couldn't get my Hydra PCMCIA card to work on my A1200 with it unless I applied some (now long forgotten) patches to hydrapcm.device with NSDPatch.
  • »23.04.23 - 20:56
    I didn't try another stack. Kind of gave up on it. At least the FM801 card worked :)
    [ Edited by HammerD 25.04.2023 - 18:19 ]
  • »25.04.23 - 23:19
