Webrings.
  • Targhan
    Posts: 2833 from 2003/2/8
    For those of you who might be interested, MorphZone can now host webrings. Three have been created to start with, MorphOS, Pegasos, and PegXLin.
    The Webrings can be found from this LINK, or from the Mainmenu on the lefthand side of the site.
    If you wish to add your site to one of the webrings, or even to have a new webring created, please contact Mithalas
    :idea:Targhan
  • »24.12.03 - 00:16
    Senex
    Posts: 498 from 2003/2/17
    Access denied to the link...
  • »24.12.03 - 08:00
  • Targhan
    Hrm... Okay...? is this logged in or not? (it shouldn't matter, I set permission on that module anon.) Also, since I just recently lowered the access restriction, you may need to logout and back in...
    :idea:Targhan
  • »24.12.03 - 08:05
    Senex
    Hm... If I'm logged out, I can access it - but once I re-login, permission is denied again.
    Btw: For the Peg-Webring I'd suggest Pegasosforum.de and PegasosPPC.de - both german, btw., in case you want to create national branches of the webrings.
  • »24.12.03 - 08:16
  • Targhan
    Try it now. :-)
    And, I think the language + topic webring may be a good idea. What do others think?
    :idea:Targhan
  • »24.12.03 - 08:21
    Senex
    Works now - thank you! :-)
  • »24.12.03 - 08:26
  • Targhan
    No problem, I'm glad you cought it. Usually, things propogate up. If you're an admin, you get all the rights of a registered user plus the extra permissions for the area you admin. That does not work on top of anonymous though. Sometimes I'll forget that. Anyway, good catch!
    :idea:Targhan
  • »24.12.03 - 08:37
