I hate transparency!
    mt12345
    Posts: 72 from 2011/4/4
    How to DISABLE pull-down menu transparency?
  • »23.06.11 - 14:03
    Posts: 2984 from 2003/3/5
    By editing the SkinConfig file of a skin of your choice.
  • »23.06.11 - 14:22
    mt12345
    OK. Where do I find the file?
  • »23.06.11 - 15:13
    Posts: 1246 from 2004/2/8
    A quick guide for a default system skin - Ferox:
    1. Open "SYS:MorphOS/Prefs/Skins/Ferox"
    2. Find "SkinConfig" file, right-click on it and choose "Edit"
    3. Find MENUTRANSPARENCYLEVEL (should be 25) and change it to 0
    If you're using an external skin, you should be able to find it in SYS:Prefs/Skins
  • »23.06.11 - 16:22
    Posts: 2027 from 2003/2/24
    If using default skins, I would copy the skin (for example Ferox) dir into SYS:Prefs/Skins directory before editing it. And probably better to rename it too (for example FeroxEdit). Then edit it for your needs and take it in use from system settings. This way you won't lose it in the next MorphOS update.
  • »23.06.11 - 17:18
    mt12345
    Thanks a lot!
    I was looking in system/prefs/skins whilst the skins are located in system/morphos/prefs/skins
    Bit confusing because folder 'morphos' is hidden..
  • »26.06.11 - 18:37
