MUI help bubble
    dake
    Posts: 204 from 2007/9/14
    how to disable mui help bubbles? Mui settings seems to have no effect.
  • »27.12.09 - 20:16
    Sprocki
    Posts: 128 from 2005/2/23
    Ambient -> Preferences -> MUI -> Help -> disable "when holding ..." and "when pressing ...". Save at the end.
  • »27.12.09 - 23:35
    dake
    Thanx for the tip, but i tried this and it seems to have no effect here:(
    Can you please verify that the settings work.
  • »28.12.09 - 08:41
    igracki
    Posts: 389 from 2003/2/25
    I just tried it with yam, and it works, like described.
    BTW:
    Why do help bubbles also appear, when a window is inactive?
    Would be nice, if it would be adjustable.
  • »28.12.09 - 11:48
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Probably because you use "mouse actions over inactive window" option in icontrol settings.
  • »28.12.09 - 13:56
    igracki
    Yes, I use this feature.
    Would it be possible to leave out help-bubbles from this feature?
  • »28.12.09 - 17:09
    dake
    Hmm i was a bit unclear earlier:)
    My problem is Ambient help bubbles,can someone confirm that the settings to disable help bubbles work.
    I gave a registered MorphOS Mac mini to my parents but they have some problems because they are old and dont click so fast on icons, alot of times help bubbles come up and block the click. I managed to change the help bubble from "comic" to "rectangle" and now the bubbles dont block the click anymore :) but is there a way to completely remove this bubbles in Ambient?
  • »29.12.09 - 09:55
    igracki
    Ok, it seems that you can't remove the help bubbles from the icons on the desktop, but you can remove the bubbles from the panels!
  • »29.12.09 - 15:23
  • Fab
    Fab
    Ambient bubbles on icons are triggered in a custom way (for a reason), so they are unaffected by MUI settings related to that.
  • »29.12.09 - 15:34
    dake
    Thanks Fab, may i ask what reason? just curious:)
  • »29.12.09 - 20:13
