MUI info
    Posts: 564 from 2004/4/15
    @itix
    sorry itix, but asking questions is the second or third step,
    first i have get into the topic, with some docs.
    But there aren't any simple examples for mui.
    Progrmming for Mos/mui is very hard in comparsion
    to qt4/java because of lack of good documentation.
  • »07.04.09 - 23:20
    Posts: 12080 from 2003/5/22
    > Was the information ever backed up?
    You could try the Wayback Machine.
  • »08.04.09 - 00:11
    Posts: 1516 from 2003/2/24
    You are right. Well, many years ago I wrote simple example application for MUI: Simple Calculator which was also on MDC. It is a start but as usually developers are not good at making good docs.
    We probably need DocWiki or something...
    Oh, I almost forgot. There are also
    Calculator 2,
    Calculator 3,
    Calculator 4 and
    Calculator 5 examples. The fifth example is most advanced and the first example is just simple one.
    [ Edited by itix on 2009/4/8 9:12 ]
  • »08.04.09 - 07:09
    Krashan
    Posts: 1107 from 2003/6/11
    Maybe I should propose a bounty for translating and updating this ;-).
  • »08.04.09 - 11:33
    HenryCase
    Posts: 39 from 2008/1/2
    @Andreas_Wolf
    I already tried the Wayback Machine, no joy. What we need to do if the info isn't backed up is contact the authors directly so we can get the MUI tools and information again. Anyone recognise these names (and know if the people are still active on any Amiga boards?)?:
    Jason Birch
    Klaus Melchior
    Ellis Pritchard
    Eric Totel
    Stephen Vermeulen
    Malik Schreiber
  • »08.04.09 - 12:20
    Beamish2040
    Posts: 44 from 2009/4/2
    @HenryCase
    I found this link after searching a bit. Seems like there may be some good examples. I'm at work so I cannot open the files right now.
    Edit:
    Taking a closer look at the files on this site it appears to be a mirror of Aminet. It might be nice to go through the examples and create a document or web site showing all the examples and how to use them. Perhaps that can become my life's mission. If only I could get more then a half hour a day to work on this stuff. :-P With all that said ShInKurO's book is coming along nicely and is also covering this material.
    [ Edited by Beamish2040 on 2009/4/8 10:35 ]
    [ Edited by Beamish2040 on 2009/4/8 10:38 ]
  • »08.04.09 - 15:11
    Golem
    Posts: 766 from 2003/2/28
    @Beamish2040
    You managed to find an Aminet mirror, have a look here for a better overview.
    @HenryCase
    You should take a look there as well, you will find some files from the sites listed on the SASG page. I don't know what your problem is with IRC, but if you need any (immediate :)) assistance, that is probably the best place to go.
  • »08.04.09 - 15:39
    Beamish2040
    Golem wrote:
    @Beamish2040
    You must have been wrting this while I was editing my post. :-)
  • »08.04.09 - 15:48
    HenryCase
    It's like eliot said, IRC is okay but I'm not going to expect anyone to hold my hand from start to finish in creating a MUI app, code line by line beside me. Even if someone was willing to do that, what about when another MUI newbie comes along, they're going to need similar assistance, and the IRC conversation isn't likely to be stored, so it's duplicating work for those in the know. Much better to have pre-written resources and be able to ask questions after trying to understand them yourself.
  • »08.04.09 - 21:40
    ShInKurO
    Posts: 36 from 2008/5/30
    Unfortunately these days almost nobody is developing native Amiga applications anymore...
    My blood flush into NoWinED sources :-P
  • »09.04.09 - 07:05
    ShInKurO
    krashan:
    I've seen into 3+ lessons many examples about each MUI class, I don't believe I'll write about that because I'm concentrated about general aspects and many other important parts of MUI programming which are difficult for a beginner... However I believe that kind of lessions are good, if my guide and that guide would be in english we can join them, we can obtain a good referring to MUI...
    [ Edited by ShInKurO on 2009/4/9 9:01 ]
  • »09.04.09 - 07:09
    @itix
    very good examples, thx!
    @all
    Wee will really need a Wiki or doc with examples like Java or qt.
    Autodocs are not stae of the art.
    It's hard work, but if the mos community want to get new developers, it's
    essential. I am also waiting for new sdk and hopefully integration
    in Cubic IDE.
  • »09.04.09 - 08:01
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    IMO the examples coming with MorphOS SDK or MUI SDK itself are good and show most aspects of MUI. class1/2/3.c should just be extended a bit to show how to add custom methods/attributes to a custom class.
  • »09.04.09 - 13:42
    Beamish2040
    @all
    How out of date are the mui files on AmiNet? Are they even worth using as a reference? Are there implications in publishing the documentation as HTML on a web site?
  • »09.04.09 - 14:08
    ShInKurO
    Beamish2040
    They are not update from very long time, so you can't find all good MUI basis programming into muidev archive...
  • »10.04.09 - 10:20
    While not updated for years they are still useful. Only problem with those old examples is they wont compile out of the box with GCC.
  • »10.04.09 - 15:21
    Beamish2040
    It will be a good learning experience to get the examples to work. Perhaps I could document it on wiki page or something?
  • »10.04.09 - 16:47
