MorphOS PowerUP and Prometheus PCI?
    Painkiller
    Posts: 128 from 2007/11/19
    Any change getting MorphOS to work with Voodoo 3 and Prometheus PCI Busboard?
  • »11.01.09 - 15:43
    Simon
    Posts: 809 from 2008/7/6
    not sure...I think only GREX is supported.
  • »11.01.09 - 18:05
    Painkiller
    Doesn't MorphOS PowerUp use OpenPCI or is it specific to GREX openPCI solution?
    Could any of the devs shed any light on this or maybe add support if it doesn't work out of the box :) ?
  • »12.01.09 - 07:45
    Simon
    openpci is about drivers for PCI cards, .. you still need seperate drivers for the GREX or Mediator or Prometheus
  • »12.01.09 - 11:52
    Posts: 12405 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5814&forum=42
  • »12.01.09 - 13:41
