Fonts on sputnik
    JohnFante
    Posts: 156 from 2006/9/4
    I am not sure if this is a PowerUp problem (and this problem have proberly been asked before) but when I install the latest Sputnik beta it fails in installing the fonts. And I have installed XADmaster.
    Is there somwhere I can download the fonts manually?
    Thank you in advance!
  • »10.05.08 - 16:20
    roschmyr
    Posts: 206 from 2003/2/20
    ask google for microsoft and corefonts
  • »11.05.08 - 00:01
    JohnFante
    Hmm. Strange.
    I downloaded the corefonts on my pc. Extracted and copied them over to the fonts directory in MOSSYS. Sputnik startes fine but there are no visible text.
    I am doing something wrong?
  • »11.05.08 - 15:17
    AmigaMancer
    Posts: 265 from 2005/8/25
    Installer works fine independently of the computer you use to run MOS.
    I don't know why it failed for you, but you can download the fonts manually, by loading the install script to a text viewer and copy-paste the URLs of the fonts to a browser. Then, you must decompress them using Voodoo-x for example.
    If you still have problems, run snoopdos to see if there is something missing.
    [ Edited by AmigaMancer on 2008/5/11 16:46 ]
    Amiga 1200 user.
  • »11.05.08 - 15:43
  • HAK
    Posts: 221 from 2003/2/24
    Hi JohnFante,
    I assume that the ttengine2.database file that will be installed in
    ENVARC: points to the fonts that Sputnik is using.
    The enclosed one looks for SYS:fonts/_ttf/... paths.
    If you installed them in your MOSSYS:fonts/... path you might have to
    correct the paths or move them to your SYS:fonts directory.
    Bye HAK
  • »12.05.08 - 01:16
    JohnFante
    Hi HAK
    Huge thanks. That did the trick :-)
  • »12.05.08 - 06:51
