How to install MOS PowerUp from CF-card to a A1200?
    Painkiller
    Posts: 128 from 2007/11/19
    since I don't have a CD-ROM drive on my A1200 I recently bought a PCMCIA-CF adapter for my Amiga and I would like to test out MOS PowerUp, but I couldn't find a way how to install it from the flash drive.
    Any help would be greatly apreciated.
    Maybe a tutorial :D
    [ Edited by Painkiller on 2007/11/19 19:04 ]
  • »19.11.07 - 15:04
    VooDoo
    Posts: 189 from 2005/8/24
    hmm..You have MOS iso on flah drive or hdd??? Simple mount this ISO whit virtualCd and install it!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »19.11.07 - 18:03
    Painkiller
    Well I'm a bit confused as the install instruction are "Create a bootable partition and copy all the files from the CD to it. Now launch a text editor and read the instructions in partition:s/startup-sequence to tweak it to meet your needs. The partition may have a low boot priority - remember to set the
    bootdevice option in that case! It is better not to set the MorphOS partition as your default boot partition on the initial install. In order to boot, go to the early startup menu and boot from the MorphOS partition."
    With what tools do I create that bootable partition and how?
  • »20.11.07 - 05:30
    Posts: 3215 from 2003/3/5
    I'm not sure MorphOS handles PCMCIA on PowerUP. I think a ide 2.5'' -> CF converter would be a better choice here.
    As for partitioning, try HDInstTools.
  • »20.11.07 - 05:43
    Posts: 2065 from 2003/6/4
    Just use HDToolbox from your 68k AOS installation and create a partition for MOS. Somewhere there are checkboxes for bootable and automount. Check these on. Also set the bootpri to an appropiate value (b4 your MOS installation runs fine, keep it lower than the 68k system partition, once MOS ran fine I happily set the MOS partition boot pri higher than the 68k partition's pri)
    [ Edited by Zylesea on 2007/11/20 17:09 ]
  • »20.11.07 - 14:08
