Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
IT WORKS !!!!!
SSSMoves
# 1
Posts: 62 from 2003/7/30
This night my peggy comes to live with an
ATI 9100.
Now im the most happy human being on the planet (with other users as well hehehe)
I have an 250GB HD and the partision will not above the 4.5 GB. What's happening here??
05.09.03
23:23
Targhan
# 2
Posts: 2833 from 2003/2/8
Congradulations, and I think I had a simular issue. Of coarse, my drive was only 40Gig. Still, after some fiddling it can be done. The bigger problem is when you try to use a program that can't see past 4G....
Targhan
MorphOS portal?
www.MorphZone.org
06.09.03
01:39
jah
# 3
Posts: 69 from 2003/3/24
tools/scsiconfig, Config Drive, Optimal Geometry
save, reboot and go back into scsiconfig to check how much is
available for partitions
06.09.03
02:23
DSLCC
# 4
Posts: 246 from 2003/5/14
Very cool! :)
Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock!
06.09.03
05:40
warface
# 5
Posts: 653 from 2003/2/24
Congratulations!
06.09.03
11:42
