MorphOS 1.4
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Yes, the installer is a simple script that allows you to install boot.img to the Boot partition and copy a new System drive to a partition. ...this does include Apps, Tools and Utilities etc. as well as MOSSYS: so if you move any of thes about ... beware you may end up with redundant versions.
    Regarding an upgrade...be sure to check MOSSYS:Libs , Classes etc. against the user SYS:Libs etc. in case more functionality is added in a new release and your old 68k/whatever version is still hiding away....
    Steve :-D
  • »29.07.03 - 19:44
    Posts: 38 from 2003/4/3
    According to Ralph Schmidt the Audio Problem with AGP Cards is a feature of the ArticiaS, so no way to cure it.
    I really hope the Pegasos 2 is leaving behind all this problems, after all, there seem to be more problem with the pegasos then with AmigaOnes :-(
  • »30.07.03 - 07:55
    warface
    Posts: 653 from 2003/2/24
    I hope we can have a "Changes" list compared to 1.3. Exploring a new version is fun, but what if we miss out something? :-)
  • »30.07.03 - 10:37
    td741
    Posts: 224 from 2003/4/2
    I heard the same, but I wondered if they had a means to patch it in the meantime. It's probably the most annoying thing so far for me. ;)
    Not sure about that one just yet. The AmigaOne's onboard Audio still doesn't work. It's apparently some sort of "Southbridge initialisation issue".
    Apparently the audio bug we get in MOS isn't there when running Linux?
    Steph
  • »30.07.03 - 15:08
