MorphOS 1.4.2 crash
    Posts: 236 from 2003/7/28
    Ok so I'm using my system with the following applications open:
    MorphOS 1.4.2 (of course)
    AmIRC 2.2
    CPU Monitor 1.4
    Gelbespanel
    Statline
    IBrowse 2.3
    Remote Desktop Client
    Aminetradio 3.x
    Jabberwocky (latest release)
    Other notes: Latest AHI just released, onboard audio, pegasos-1 with april2 fix
    I'm playing back an mp3 and surfing. All of a sudden I get a total system freeze, the sound blaring in a loop in the speakers. Ok, great I've got debug serial output from my PC. But it doesn't seem to indicate any error.
    I have posted the crash log here if you want to look. The very end of the file is where the crash occured, after that I rebooted.
    Anyone out there have any ideas? Do I need to turn on MORE debug options?
    Click for the Crash Log
    Thanks,
    HammerD
  • »09.08.04 - 03:16
    Robin
    Posts: 741 from 2003/2/24
    If you've AmIRC on anyway I'd recommend to throw away
    Jabberwocky ... I heard alot of people who have crashes
    with it, instantly or after a while ... there is bitlbee
    as a replacement you could use. I've only tested/used with
    ICQ but it should work for all ...
    http://my.morphosi.net/bitlbee.htm
  • »09.08.04 - 05:22
    Posts: 889 from 2004/1/24
    Well...I'm not sure, and I'm still testing, but I've got the feeling that my machine has become more unstable since I've installed the newest version of AHI.
  • »09.08.04 - 09:05
    DJBase
    Posts: 744 from 2003/4/6
    If you've AmIRC on anyway I'd recommend to throw away Jabberwocky ... I heard alot of people who have crashes
    This only happens with Pre6 which was removed due to a bug in sound routine. All other Versions are stable.
  • »09.08.04 - 13:40
