Dual gfx card w/Quake2 and HereticII
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Okay...I added a PCI Radeon so Linux can play nicely along with my Voodoo3500 in the AGP slot.
    I'm having problems getting Quake2 (Hyperion) and HereticII(Hyperion) finding a screenmode.
    I get a 'no suitable driver found' or No screen type error when trying to use Hardware 3D. I tried switching WB display to the Voodoo...when I do this, Heretic II can be made to work in Window mode (bit not FS mode) Quake2 still refuses to run (even windowed).
    I tried 'clear all screenmodes' too
    Both applications were running fine prior to the addition of the Radeon.
    Oh...MOS 1.4.2 of course :D
    Anyone got a way to tweak this?
    FWIW Shogo2 runs fine as does Wipeout2097, both with 3D HW acceleration on the Voodoo
    Descent runs fine...well, until it crashes that is (buggy piece of crap) :-/
    Steve
  • »19.06.04 - 02:38
    Miky060
    Posts: 694 from 2003/2/24
    Yes, when you want to run QauekII and Heretic you have to set your Ambient/WB display to be opened on Voodoo and save AND REMOVE RADEON DRIVER FROM DEVS:MONITORS. A bit boring, but it will work (obviously after a reset).
    If you don't do this the application does not allow you to selcet the screenmode/gfx board and try to use the Radeon instead of the Voodoo. The new TinyGL should let you choose on which screen (GFX board) open the game...
  • »19.06.04 - 09:25
  • JKD
    JKD
    Thanks Miky...a shame that is the only solution right now :-/
    Something else I need MOS1.5 for ... <raised eyebrows>
    Actually if MOS1.5 has Radeon drivers.....the Voodoo can go in the trash so it's kind of irrelvant :-/
  • »19.06.04 - 19:24
    bigfoot
    Posts: 508 from 2003/4/11
    This has nothing to do with TinyGL. Hyperionware uses MiniGL, which is something completely different.
  • »19.06.04 - 21:03
