Peggy Hang when open any browser!!!
    Posts: 3 from 2004/5/14
    Hi !
    I have a pegasosII G4 with 512MB RAM ,Voodoo 3 3000 AGP ,Nec DVDRW 2500 and 80GB Hdd...
    I have a router and miami dx configured to use it...
    When I open Voyager,Aweb or Ibrowse it load an half of page and Hang my PEG!!!!!!!!!!
    I have changed NetCard with a 8139 PCI but problem is the same....
    Where is the problem?
    Anyone could help me?
    Thankyou!
    Dave.
  • »20.05.04 - 21:02
  • jah
    jah
    Posts: 69 from 2003/3/24
    first give a try while browsing offline documents
    this may help to identify the problem
    check then check if you dont have old prefs files for the browser or
    old mui config files
    if you have another computer you can link it to the serial port : you
    will see infos when your peg hang
  • »20.05.04 - 21:54
    Jupp3
    Posts: 1193 from 2003/2/24
    Maybe you could try some other network programs, such as playing some online radio in AmiNetRadio...
  • »20.05.04 - 22:23
    Spidey
    Posts: 568 from 2003/2/24
    Or try an e-mail proggie.
    Bye,
    Spidey
  • »20.05.04 - 22:44
    DrZarkov
    Posts: 142 from 2004/3/21
    You did not install an old version of MUI like MUI 3.8, because Miami said it needs it? Delete those "new" version of MUI and remove that port from user-startup! Miami will still work!
  • »21.05.04 - 13:06
