mldonkey
    Spidey
    Posts: 568 from 2003/2/24
    Hi Miky060 and timofonic,
    I also would prefer a GUI, but this stuff also works nicely with the browser.
    I'm no expert, but I managed fairly easy to set it up :-)
    @Miky060:
    Too bad you have problems when using MLDonkey. I did have some problems with my harddrive, but it only came because I was downloading with MLDonkey, surfing, getting my mail and running that dnet-stuff at the same time. Because of the crashes (it happened several times) I got problems. Fortunately it's over now :-)
    @weiseb:
    I've installed the ABC-client on pc-side to see if the links I want to download with my Peg works.
    on pc-side it works, but the same file on Peg-side doesn't start working.
    I think I'll stop trying to download torrent-files.
    "Donkey"-files do work :-)
    Bye,
    Spidey
  • »23.04.04 - 07:14
    Posts: 1068 from 2003/3/24
    How can i connect to a Fasttrack Server?
  • »04.05.04 - 17:35
  • bas
    bas
    Posts: 40 from 2004/4/8
    @ ThePlayer
    find this rule in the downloads.ini file
    enable_fasttrack = false
    and make it true
    enable_fasttrack = true
    mldonkey should now be able to connect to fasttrack servers.
  • »07.05.04 - 12:04
  • Targhan
    Posts: 2833 from 2003/2/8
    (torrents)
    I'm still having problems with seeding. I can get mldonkey to report (through the html interface) that the seeds are there, but they are never uploaded (even after waiting days).
    What makes this a real boggle is that the files I download are actually uploading to while I'm downloading them.
    :idea:Targhan
  • »07.05.04 - 17:17
