PEGxMAC trouble with OSX
    serge
    Posts: 725 from 2003/2/20
    I tryed PEGxMAC. It is a very intellignet solution for MACOS under PEGASOS, and MACOS 9 passed the test succesfully after 1 or 2 minutes spent booting and configuring 1 file ;-) but ...
    I'm having some trouble to run MacosX.
    PEGxMAC seems to boot normaly, but I have a message in end of boot some strange.
    INIT : entering run level :5
    INIT : cannot execute "/etc/init.d/xsession.
    Is this normal or not?
    Configuring configmolrc.macos, I can run succesfully MACos 9 from an
    installation CD or my old HFS partition.
    But Trying to run MACOSX after Configuring configmolrc.macosx, There's an error
    SQUASHFS error: zlib_fs returned unexpected result 0xfffffffd
    SQUASHFS error: unable toread page, block a619958, size 396a
    /usr/lib/mol/bin/mol error while loading shared
    libraries : /usr/lib/libasound.so.2 invalid elf header
    Does somebody have an idea where is the problem ?
    Thanks
    serge
  • »29.04.04 - 12:47
    yashin71
    Posts: 37 from 2004/4/20
    Also I have the same problem, it gives me the same errors, however I have tried only with MACOS X
  • »29.04.04 - 13:00
    Druideck
    Posts: 82 from 2003/5/6
    A little off topic, but can anyone tell
    me how to make my mac partition show up
    on MAC OS9.1? Can I make it HFS somehow
    first? Thanks.
  • »29.04.04 - 15:17
    serge
  • »29.04.04 - 15:37
    Druideck
    Thanks Serge, I will give it another try.
  • »29.04.04 - 20:42
    Estrayk
    Posts: 142 from 2003/12/30
    Testing.... without success... :(
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »29.04.04 - 23:52
    Estrayk
  • »02.05.04 - 12:52
    Estrayk
    fixed! now.. MacosX instalation is showed! but it crashed copying language files to hard drive!
    the computer crashed 100% I cant do nothing.. just reset!
    :( any idea?
  • »03.05.04 - 00:09
