Easy Way to get ADF Games to run MorphOS 3.18?
    Posts: 107 from 2023/12/1
    Is there an easy way to allow MorphOS 3.18 to play games I may download in ADF?
    I purchased RogueCraft for Amiga from Itch and can't get it to run on my Amiga OS 4.1 X5K at the moment and having issues getting RunInUAE installed on it and then I thought, maybe now is a good time to explore the trial version of MorphOS 3.18 I have on my X5K.
    Is there an easy to follow step-by-step for getting games for Amiga to play on a MorphOS system where I can download the apps and try it?
    Thanks
    TJ
  • »04.01.25 - 18:46
    tolkien
    Posts: 557 from 2013/5/29
    Why not install whdlopener?
    https://www.morphos-storage.net/?id=1531930
  • »04.01.25 - 21:42
    Are there any other files I need to download in advance to allow this to install and work?
    Any ROMs or the like?
    Thanks
    TJ
  • »04.01.25 - 21:59
    tolkien
    For sure you need some kickstart file.
    Im away from my MorphOS machine but download It and read the docs.
    I remember It very easy to install and use.
    Then you can play adf and whdload games with a simple double click.
  • »04.01.25 - 22:12
    Posts: 895 from 2003/3/4
    If you have OS4 then you'll likely already have the kickstart files.
  • »05.01.25 - 14:37
    Yes and I have Amiga Forever around here someplace too.
    I will explore this.
    Thanks
    TJ
  • »05.01.25 - 14:44
    Posts: 2193 from 2003/2/24
    I've been using filetypes you can find from the Bonus directory in the E-UAE archive. Then you can just double-click an ADF to run it, or right-click to select from the context menu if you want to run it in different setups like A500 or A1200 config.
  • »06.01.25 - 11:03
