Port of BitRiot
    Papiosaur
    Posts: 2408 from 2003/4/10
    Hello,
    i'm trying to port BitRiot on MorphOS.
    i have added includes and libs for SDL2 and OpenGL in the CMakeList.txt (all seems ok after a CMake ..) but i have a problem when i "make" because the game need RmlUI...
    Do you have any idea for this problem please?
    Must i port it to MorphOS?
    RmlUi
    or adapt something equivalent on MorphOS?
    Thanks for your help.
  • »14.09.24 - 08:28
    Posts: 2451 from 2003/2/24
    This one?
    You got to decide at which layer you want to "port" it.
    Either you port everything it depends on, or rework the code to use CGX/MUI or what ever is suitable.
  • »14.09.24 - 08:44
    Papiosaur
    @Kronos: yes, i have added the link after.
    Thanks for your answer.
    What is the more easy? :-D
    [EDIT] Normally SDL2 game don't have necessary CGX/MUI adaptation? Maybe i can remove this dependency and replace it by some SDL2 functions for the window/screen?
    [EDIT2] I have just see v1.3 seems not need RmlUI or librocket, i will try to port this version. Cross fingers :-D
    [EDIT3] v1.3 dont want to load bitmaps/wall.bmp...
  • »14.09.24 - 08:46
