Posts: 421 from 2003/2/24
Papiosaur wrote:
Hi Primax,
it's an Hollywwod script, i can execute it on MorphOS with Hollywood command from Hollywood 10.
I try to test it more to see if all is Ok and compile it on MorphOS (no need Hollywood command after compilation).
PS: translations work, i've contacted the author to say him i would like port it on MorphOS.
The original author could also compile it as an Hollywood Applet, then it would work on all platforms!
And the file size is only 20kb instead of 4MB.
I just tried it, and it works fine here!
Maybe I should "switch" my gTranslator.sbar to deepL...
