Posts: 1476 from 2012/11/10
walkero - Yes, thanks a lot for your hard work in implementing this editor, and fixing what you found wasn't as it should be.
It makes a nice change to find someone else, besides
jPV and probably a few others here in the MorphOS realm
, creating a program side-by-side with one for OS4.x users and creates the same package for MorphOS, which sadly seems to happen less often than it might, so KUDOS to you!
