Heretic II port new version?
    PPCenby
    Posts: 16 from 2022/12/4
    Hi! Does anyone know if the new version of Heretic II will work on MorphOS?
    https://www.amiga-shop.net/en/Amiga-Software/Amiga-Games/Heretic-II-for-AmigaOS-4::1354.html
  • »22.03.24 - 21:33
    zukow
    Posts: 648 from 2005/2/9
    68k version should work
  • »22.03.24 - 21:51
    Posts: 12323 from 2003/5/22
    How can it? It's an OS4 version.
  • »22.03.24 - 23:12
    That's not released yet, isn't it? And it will surely run slower on MorphOS than the old PPC version for OS3/WarpUP.
  • »22.03.24 - 23:13
    PPCenby
    Yes, but unfortunately under current versions of MorphOS the old PPC version of Heretic II crashes after the tutorial when the first level loads.
    [ Edited by PPCenby 22.03.2024 - 18:25 ]
  • »23.03.24 - 00:16
    Posts: 891 from 2003/3/4
    The game plays a video immediately before starting play in the main campaign. That's probably where it's crashing. Maybe try disabling the videos?
    You got the tutorial working, so you've conquered the hardest challenge - actually getting Warp3D to work. As far as my now very dim memory recalls, the Warp3D wrapper used Rave and this was dropped for Radeons after the 9xxx series.
    [ Edited by KennyR 24.03.2024 - 19:34 ]
  • »24.03.24 - 20:28
    Cego
    Posts: 734 from 2006/5/28
    works here nicely
  • »24.03.24 - 21:37
    > Rave […] was dropped for Radeons after the 9xxx series.
    With R300, so after Radeon 9250. TinyRave to the rescue!
  • »24.03.24 - 23:31
    PPCenby
    KennyR wrote:
    [The game plays a video immediately before starting play in the main campaign. That's probably where it's crashing. Maybe try disabling the videos?
    How do I disable videos? Is there a console command? There doesn't seem to be an option in the menu as far as I could see.
    I'm running on the "silent upgrade" Mac Mini with the 64MB Radeon 9200.
  • »25.03.24 - 19:23
  • man
    man
    Posts: 133 from 2019/11/11
    rename or delete the videos
  • »25.03.24 - 22:20
    PPCenby
    I can't find the videos in the Heretic II drawer.
  • »07.04.24 - 18:33
  • man
    man
    have you search base/videos
  • »08.04.24 - 07:19
  • man
    man
    shows alls drawers
  • »08.04.24 - 07:19
    PPCenby
    The drawer's empty...
  • »09.04.24 - 20:28
  • man
    man
    you can try by the system 'search'
    with the drawer of heretic 2 use mouse with search and make choice type 'video'
    but i m not sure this applicatio of morphos work perfectly
  • »10.04.24 - 07:55
    Possibly why the game is crashing then - looking for videos and not being able to find them, rather than finding them and crashing when trying to play.
    There should be three videos in base/VIDEO - Bumper, Intro and Outro. I don't have access to my old install of the game on MorphOS any more, but the PC originals are .smk (smacker), while Hyperion had to change that to something else for legal reasons.
  • »12.04.24 - 08:49
    PPCenby
    Thanks for the information, everyone! I copied the .smk files from the VIDEO drawer in disc B to the one on the hard drive. That solved the crashing issue, and I can get into the game now! However, when the video plays, there's just a black screen with audio only.
  • »12.04.24 - 17:30
    I think that may always have been the case on MorphOS.
  • »12.04.24 - 22:15
  • man
    man
    i have not find wizard.library mos so i use wizard.library 45.1 68k (to see if the last on 0s3.2.2 if better)and rtgmaster.library 42.2 mos for the old heretic 2 perhaps the new heretic 2 needs too
  • »14.04.24 - 15:04
  • man
    man
    a part of my config of this game but i have no music for moment
    set compass "1"
    set r_detail "3"
    set cl_yawspeed "70"
    set dm_no_bodies "0"
    set ami_soundcache "1500000"
    set con_alpha "0.7"
    set advancedstaff "1"
    set allow_download_sounds "1"
    set allow_download_models "1"
    set allow_download_players "1"
    set allow_download_maps "1"
    set allow_download "1"
    set gl_skinmip "0"
    set gl_fog_enddist "1024.0"
    set gl_notileclear "0"
    set gl_polyoffset "0"
    set gl_dither "1"
    set gl_fontfix1 "256"
    set gl_fontfix2 "1024"
    set gl_mintriarea "1.0"
    set gl_texturecache "26214400"
    set gl_closeworkbench "0"
    set gl_sync "1"
    set gl_buffers "3"
    set gl_forcedepth "32"
    set hostname "Parthoris"
    set sv_jumpcinematic "0"
    set sv_reconnect_limit "3"
    set vid_ref "gl"
    set vid_xpos "0"
    set vid_ypos "0"
    set vid_brightness "0.562500"
    set win_noalttab "0"
    set gl_driver "MiniGL/Warp3D"
    set gl_ext_palettedtexture "1"
    set viewsize "100"
    set s_volume "0.900000"
    set s_sounddir "sound"
    set s_khz "44"
    set s_mixahead "0.2"
    set cd_nocd "1"
    set adr0 ""
    set adr1 ""
    set adr2 ""
    set adr3 ""
    set adr4 ""
    set adr5 ""
    set adr6 ""
    set adr7 ""
    set adr8 ""
    set cl_stereo_separation "0.4"
    set lookspring "1"
    set lookstrafe "0"
    set mouse_sensitivity_x "4"
    set mouse_sensitivity_y "4"
    set doubletap_speed "100"
    set m_pitch "0.022"
    set cl_camera_dampfactor "0.2"
    set name "Corvus"
    set skin "Corvus"
    set skindir "skins"
    set rate "2800"
    set msg "1"
    set fov "75.0"
    set in_mouse "1"
    set in_joystick "1"
    set file_gamemsg "gamemsg.txt"
    set file_levelmsg "levelmsg.txt"
    set gl_particle_min_size "2"
    set gl_particle_max_size "40"
    set gl_particle_size "40"
    set gl_particle_att_a "0.01"
    set gl_particle_att_c "0.01"
    set gl_picmip "0"
    set gl_ext_swapinterval "1"
    set gl_ext_gamma "1"
    set gl_ext_pointparameters "1"
    set gl_swapinterval "1"
    set cl_doautoaim "1"
    set gl_lockmode "MANUAL"
    set s_modeid "196610"
    set vid_mode "9"
    set vid_gamma "0.625000"
    set vid_contrast "0.837500"
    set snd_dll "ahisnd.dll"
    set shownames "1"
    set sc_framerate "20.0"
    set s_loadas8bit "0"
    set no_middle_text "0"
    set gl_texturemode "gl_linear_mipmap_linear"
    set gl_sortmulti "5"
    set gl_shadows "1"
    set gl_particle_att_b "0.0"
    set gl_modulate "1"
    set gl_ext_multitexture "5"
    set gl_driver0 "3DfxGL_Ht2dll"
    set freelook "1"
    set crosshair "4"
    set cl_run "0"
    set cl_camera_fpheight "0.0"
    set blood_level "2"
    set autoweapon "1"
    set pakfirst "0"
    set vid_fullscreen "1"
  • »14.04.24 - 15:35
    It's nothing to do with your config. The old cdplayer.library does nothing on MorphOS. You need the MorphOS replacement to play CD audio.
    https://aminet.net/package/util/libs/cdplayer_lib_ahi
  • »15.04.24 - 23:06
  • man
    man
    i forgot to write chunkyppc.library 31 .library need too and try see for the data heretic 2 to aminet if that works for morphos
  • »19.04.24 - 13:53
    PPCenby
    I'm now on the swamp level and experiencing a weird glitch in which all the graphics do some weird tearing in front of the skybox. Does anyone have any suggestions if this issue might be solvable?
  • »19.04.24 - 21:28
    Try turning off the fog.
    gl_fog_broken 1
    in the console, I believe.
  • »25.04.24 - 20:27
