Chrysalis Pack
    Brumiga
    Posts: 241 from 2004/4/3
    @Papiosaur,
    Here is my feedback after testing as requested.
    The installation goes well until the end but the exit window remains empty. I looked at the installation script of this beta version with that of version 3.17 and I found a small difference which explains the blank, run "wbrun lha >con: x -q". The -q is for 'quiet' do I suppose, it is not present on the previous version script.
    You still left the line with a loop in the user-startup to check if rexxsyslib.library has been renamed while the installation script carries out this renaming towards the end. Please remove this duplicate.
    You chose to install amissl but it is not used. After searching through Ambient I found 'amissl:' in 3 programs, rnoradio, rnowidgets and rnoxfer. Did the author, JPV, leave traces of amissl in the rnoradio code for morphos as well as in the rnowidgets code on amigaos 4.1, the same for rnoxfer on amigaos 4.1 and amigaos 3.x? The author should be asked to check whether traces of amissl are actually present in these 3 programs or not.
    Here are some ideas to explore before a final version of Chrysalis for MorphOS 3.18.
    Brumiga
  • »31.01.24 - 09:12
    Posts: 2028 from 2003/2/24
    None of these programs use AmiSSL on MorphOS anymore (and RNORadio never did). I've just made a generic download function that I use for all platforms, and it has an AmiSSL check for other platforms which leaves couple of traces on MorphOS binaries too.
  • »05.02.24 - 08:15
    NewSense
    Posts: 1476 from 2012/11/10
    You had left a space in the first "[url=_" section, so the linked file didn't work-trigger the download, as the address was incorrect initially, I have corrected this so the link now works. 8-D
  • »18.02.24 - 03:19
