Multiple monitors - change second monitor settings?
    matt3
    Posts: 747 from 2004/2/10
    I'm using 2 monitors off my one video card and have been very happy with how MorphOS handles multiple monitors.
    I wanted to change my secondary monitor and add a new resolution but under system preferences/monitors it only lists my primary display.
    Is this even possible?
  • »30.10.23 - 19:12
    Trekman
    Posts: 47 from 2020/11/10
    ...with MorphOS 3.18 my second monitor did not work any more. So I used the Monitor driver from 3.17 instead and it worked again. I then could adjust the resolution for the secondary monitor in prefs again.
    See here : https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=13557&forum=3#156127
  • »31.10.23 - 12:01
    Posts: 545 from 2003/4/11
    It might change in the future but for now the modes of the secondary display are autogenerated and can't be modified.
    @Trekman:
    It has been reported that there is some regression with PowerMac7,x machines and secondary display support on Radeon96x0 cards, so this might be what you were running into with 3.18.
  • »31.10.23 - 16:24
    Trekman
    Yes, my machine is a PowerMac7,3 with a Radeon 9600.
    Think youre right with this.
  • »31.10.23 - 17:30
    matt3
    Thanks for letting me know.
  • »31.10.23 - 18:21
    igracki
    Posts: 460 from 2003/2/24
    Is multi monitor supported with a Radeon X1900 GT in a PowerMac 11,2?
    I am asking because I only see a mirrored image of the first monitor and I only have a RadeonX1900GT in my mode list in screens preferences, no RadeonX1900GT.1 which should be there, as far as I understand.
    I have one port of the gfx card connected with a hdmi adapter to the hdmi input of the monitor and the other port to the dvi input of the same monitor. The screens on both inputs are the same.
  • »29.01.24 - 12:30
    igracki
    Okay thanks, I first wanted to test with two inputs on same monitor if it works.
    I didn't know I have to have 2 Monitors to use this feature.
  • »29.01.24 - 13:42
    igracki
    Here I still have same mirrored modus only with two monitors.
    No extra .1 monitor in the modus section of screen prefs!?
    Am I doing something wrong or why doesn't it work?
  • »29.01.24 - 18:50
    igracki
    Just wanted to say multi monitor is now working here, my HDMI recorder was the culprit!
    If I directly connect the monitor I get the ".1" monitor modes to select a screen on the second monitor.
  • »03.02.24 - 13:18
