Posts: 2046 from 2003/4/10
Andreas_Wolf a écrit :
> if i remove "&start=5" from the link it's ok.
I mean comment #6, which is made topmost by "&start=5", with "Comments Sort Order" set to "Oldest First".
> Yes, the file "powersdl.library" 16.2 was in the DOSBox archive but alone...
Yes, I'm not aware of any other way of distribution used by its author.
@Andreas: Ok, when i was connected with my login, the order was reversed and i have only post #4, #3, #2, #1.
About distribution, maybe there is no full package for PowerSDL 16.2.
