USB joypad
    Posts: 34 from 2004/4/8
    hello,
    i use a Smartjoy Adapter Plus (PS/PS2) USB controller adapter on my Pegasos II and its works great with a standard Sony Dual Shock 2. I tried it wth Mame, SMS Plus and some other software.
    Ermm, sorry. of course this is a reply for the topic with the same name. im a little bored.
  • »08.04.04 - 10:31
    Sphinx_Ra
    Posts: 276 from 2003/3/15
    Hmmmm....
    Is the brand a "Innovation" ???
    Because i have a USB Smartjoy Adaptor here
    doesn't work here :-(
    Can you send a picture of it ???
    Thx
  • »08.04.04 - 14:33
    Jupp3
    Posts: 1193 from 2003/2/24
    I bought PS2 USB controller adapter from play but it doesn't seem to work...
    I don't blame play, just thought myself it might work, becouse it doesn't require special drivers on windows (or that's what my friend told...)
  • »20.04.04 - 08:56
    Posts: 1914 from 2003/10/19
    If you like the look and feel of the PS2 pads check out the Logitech game pads out now. I got a black one that looks and feels just like a dual shock. Its the same shape, and has the same buttons pattern even. Best of all it works on everything I have used it on so far. As an added bonus I only paid $15 for mine new at BestBuy here in the US.
  • »20.04.04 - 14:28
    Paochi
    Posts: 136 from 2004/3/23
    I have a 2 way PS2 - USB adapter.
    Both Ps2 joypad can be used under MAME on MOS :D
    I have only sometimes strange problems of latency ... I cannot say if it's a problem of MAme or the connector or the USB stack.
    I also used my PC gamepad:
    http://www.trust.com/products/productpics.htm?artnr=13016
    It run wonderfull on MOS! (the analog joystick too)
    "I hope that all my toys are, first of all, funny!" (Jay Miner)
  • »20.04.04 - 14:48
    magnetic
    Posts: 2129 from 2003/3/1
    I tried a Radio Shack usb/psx adaptor Poseidon saw it but couldnt "bind it"
    I have also a Logitech usb bad with analgue sticks how do i configure them for mame?
    tia
    magnetic
  • »20.04.04 - 22:24
    Donar
    Posts: 142 from 2003/12/27
    Did you try to bind it to rawwrap class?
    Maybe this will function. Have you also tried to boot
    up with the connector already in the Pegasos?
    My external HD refuses to work sometimes when
    i turn it on while the Pegasos is running.
    Just a thought.
    Bye
  • »21.04.04 - 14:32
    Sphinx_Ra
    @ csabanw
    I have the same Adaptor now :-)
    Only in games i can not go left or right, i did go to USB/settings, but what Button is left or right ???
    Do you have a list how you set it like standard PSX pads ???
    Like This:
    Button 1: Start
    Button 2: Select
    Button 3: left
    Etc....
    Thx
  • »22.04.04 - 17:47
    Bladerunner
    Posts: 418 from 2004/2/19
    Sphinx_Ra:
    If you select "Track incoming events", You are able to press a button, and it will be directly selceted in your Poseidon prefs. Then you can set every Button just as you want.
  • »22.04.04 - 18:25
    Sphinx_Ra
    @Bladerunner
    I notice that a few minutes ago, thx Anyway :-)
    But the problem if i want to set the right and
    left button is that "prefs" shows it as (both)
    "X Axis" dunno how to set it right :-(
  • »22.04.04 - 18:32
    Sphinx_Ra
    @Sphinx_Ra :-D
    BTW:
    The strangest thingie is like in WipeOut2079 in the
    "Menus" thebuttons left and right work but not in gameplay :-(
    HEEEEEELP !!!
  • »22.04.04 - 19:12
