MAME 0.148 and tinygl
    Posts: 123 from 2022/7/1
    Hi all
    I have a problem with MAME 0.148.MAME is with an 6000 roms installed.The problem happened even before I've installed tinygl yesterday and is that when I try to load and play sone roms it has some video intiialization error.So no video initialitation at all.
    As I am not an average or expert Morphos user at all:
    Why this happens? Is there any trick that I can play MAME roms at all under Morphos 3.18?
    I am a Morphos registered user registered between 3-5 of August 2023.
    Any ideas are welcome
    EDIT:Is there a better version of MAME avaliable? Where is if avaliable?
    [ Edited by bearerofthetorch 15.08.2023 - 19:14 ]
  • »15.08.23 - 15:38
    beworld
    Posts: 664 from 2010/2/10
    What is your version of MorphOS?
    What is your hardware and graphics card please?
    I just test on my machine (PMac G5 2.7 with X800) and all working here with MAME 0.148
    It's last version...
    I port FinalBurn Neo (somthing similar)
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »15.08.23 - 16:30
    Morphos 3.18
    AmigaOne X5000
    ATI Radeon HD 5450
    Hope this helps
    Is there another working version of MAME?
  • »15.08.23 - 17:11
    Posts: 12408 from 2003/5/22
    MAME doesn't use TinyGL.
  • »15.08.23 - 17:20
    > Radeon HD 5450
    MorphOS can't do overlay with this card. Try with overlay disabled.
  • »15.08.23 - 17:37
    OK.
    So then why doesn't work?
  • »15.08.23 - 18:05
    > Radeon HD 5450
    OK but...what is overlay?
  • »15.08.23 - 18:07
    > OK. So then why doesn't work?
    Maybe because of overlay. See comments #5 and #8.
  • »16.08.23 - 05:35
    Posts: 422 from 2019/5/9
    Try add to your config file:
    -nouse_overlays
    and to vector.ini file:
    effect none
    and look to the /doc/config.txt from MAME folder
    [ Edited by sailor 16.08.2023 - 10:18 ]
  • »16.08.23 - 06:17
    -nouse_overlays
    effect none
    OK I will try but...
    I tried but at the moment I musn't do because on Ambient on the right-click menu it musn't show any text editor.And on DirOpus I musn't do it too because sometimes it doesn't work.I have a failure related with the command DopusRT file and is frequent when I try to extract some files.
    What do you think?
  • »16.08.23 - 14:27
    OK I checked but I cannot download at all
    And the DirOpus problem of DOpusRT erriors is very important cause I need to extract files and do more things without issues.
    And about Morphos MAME I want to ask: Is there a newer or better MAME version than this MAME 0.148?
    No video inicializiaton is the last message I remember
    Thanks for your support to all of you
  • »17.08.23 - 09:55
    beworld
    No
    I dont have sources from fAb : http://fabportnawak.free.fr/mame/
    Else i can check if i can update it....
    [ Edité par beworld 17.08.2023 - 14:18 ]
    My MOS ports
  • »17.08.23 - 10:01
    No
    OK
    Then this version ust work fine with Morphos no?
  • »17.08.23 - 10:24
    > Previously I MAME 0.148 without overlay and in window and it doesn't
    > load the roms,no luck. The only option activated was joypad
    If you have overlay already disabled and your problem persists, then I'm out of ideas. Sorry.
  • »17.08.23 - 16:11
    Doffo
    Posts: 508 from 2010/10/14
    I forgot you ported it over. I will have to try it later today. Thanks for the reminder. :)
    YUUUP!
  • »17.08.23 - 17:49
    I have FinalBurn Beta on AmigaOS 4.1 Final Edition Update 2.Great emulator.
  • »21.08.23 - 10:01
