Ultraspec has Superbundles in stock now shipping
    AyoS
    Posts: 410 from 2003/8/13
    Great!!! This is good news.
  • »16.04.04 - 02:47
    ultra2spec
    Posts: 10 from 2004/2/7
    Hi katos1 !
    Hows your peg doing ? You know you can contact us direct if you ever need anything
    Regards
    Ultra Spec Team
  • »16.04.04 - 15:28
    AyoS
    Hello,
    My PegII is working very well. About two months ago I ebay'd a Voodoo 5500 agp. Just recently configured this card. It is far faster the the Voodoo 3000 agp, but what it adds in speed, it also adds with heat and Noise!! the twin fans although not too loud on their own, add to the power supply fan and cpu fan.
    That is were the Ati 9200 comes in, I am sure this card will be much more responsive than the old Voodoo 5500, while not needing a fan :-)
    Still with the Nexus case I bought from you my Peg II is still much quieter than the pc I had at my house the other day. and the pc (amd athlon 2000+) only has two fans one on the cpu and one on the powersupply. My peg with all 4 of its fans is still quieter.
    Katos1
  • »16.04.04 - 16:53
    ultra2spec
    Hi Katos1
    The voodoo5500 is ok...
    we got the 9200's need one? We use em on all our systems they run perfect
    Sorry for the late reply!
    We still have superbundles left as well:)
  • »20.04.04 - 00:13
    AyoS
    Yes,
    I definitely want the Superbundle :-D
    OT: Also, does the 9200 you stock have a fan?
    I know that the Voodoo 5500 is fast. but the drivers are not quite ready, and some things get partially garbled. But since 2D is what i need the most, the ATI 9200 would be much better...for now ;-)
    Thanks,
    Katos1
  • »21.04.04 - 15:43
    ultraspec
    Posts: 94 from 2004/1/29
    Hi Katos. No, it does not.
  • »21.04.04 - 16:42
