USB Boot for PowerMac G5
    LazarX
    Posts: 7 from 2020/4/30
    Is there a way to create a bootable USB for a PowerMac G5 from the iso file?
  • »04.11.22 - 16:47
    Posts: 826 from 2007/10/23
    Did you read this?
  • »04.11.22 - 21:40
    LazarX
    No I had not, I picked some cdrs and got a boot cd made
    I succesfully ran the installer but Morph won't boot and the Boot partition can be seen but apparantly does not have the blessing needed for it to boot.
    I'm using a PowerMac G5 7,2.
  • »14.11.22 - 04:56
    Posts: 1335 from 2004/2/8
    Did you partition your harddrive manually?
  • »14.11.22 - 05:21
    Posts: 545 from 2003/4/11
    Actually, the SD card/USB hybrid image should be bootable directly on a G5 if you change the boot-device to UD: instead of HD: in OF and you have written the RAW image to a USBstick directly...
    I wished Apple's USB boot device support had been a bit more straight forward back then but they decided to focus on Firewire for marketing reasons, it seems.
    Either way, I use this kind of boot method on all my Apple-type machines as a type of emergency boot option, so it definitely works. Of course it can also be used to update/install the latest MorphOS version.
    If it doesn't work/boot, it is most likely the type of USB device that is refused by OpenFirmware and/or the image that is not correctly written to the USB media.
  • »14.11.22 - 06:56
    Zetec-s
    Posts: 197 from 2008/7/10
    This chap has been in touch with me directly and the issue he is actually having is that MorphOS is installed but is not booting for some reason.
    He has a Boot partition and it has the right files (name wise) in it but it won’t boot.
    He actually reached out on Facebook to me as I have a G5 working but I’ve checked the basics with him and cannot really help anymore.
  • »16.11.22 - 21:46
    LazarX
    I took out the other hard drive so there's just one in the system.
    Booted off the CD again and aside from selecting region/language/time zone just went with the defaults.
    Could the issue be that it's a terrabyte drive?
    The image is the 3.17 version downloaded directly from the website.
  • »17.11.22 - 04:02
    LazarX
    I finally got things working.
    The final fix.... swapping positions of the two hard drives.
    And NOT naming my Mac partition "System">
    I now have a triple boot of Leopard, Tiger, on one drive and MorphOS on the other.
  • »17.11.22 - 06:47
    Well, "SYS" is reserved but "System" should not make any difference.
  • »17.11.22 - 13:14
    LazarX
    The install process creates a volume with System as it's name.
    As it turned out which SATA port I used was the critical difference.
  • »17.11.22 - 23:13
