Posts: 1709 from 2003/4/10
Hello,
i have a problem with mimetypes (Ambient), when i configure a mimetype (audio/mpeg for example), i would like remove Play... default entry and after herited actions are showed from "audio" but when i click on ok the tree structure is closed... and the herited actions are not saved...
It will be possible to have possibility to save herited actions and keep tree structure open after "save" please ?
[ Edité par Papiosaur 11.11.2022 - 14:12 ]
