Posts: 532 from 2012/4/28
Solo_Kazuki escribió:
Hello
Since MAME is in old versions and some games are displayed wrong, maybe someone can port newer version?
Or if nobody is interested in porting newer version, maybe some "qickfix" can be done? It might be fix of executable or just small program to run before MAME to fix display problems. Someone?
You must think that MAME's roms change with each new version and with a new MAME the old roms don't work, some games are available in these old roms.
NOTE: This problem you can find in MAME for Windos, Linux and Android.
