How to compile MilkyTracker for MorphOS
    Papiosaur
    Posts: 2409 from 2003/4/10
    Hello all,
    i would like to try to compile last version of MilkyTracker for MorphOS.
    How do i do please ?
    Thanks for your answer ;-)
    source : https://github.com/AmigaPorts/MilkyTracker/releases
  • »24.08.22 - 19:23
    bigfoot
    Posts: 510 from 2003/4/11
    Milkytracker is not the easiest project to start with. While the project does support MorphOS to some degree, the main Milkytracker source repository does not build for MorphOS out of the box, and thus it is really not a great project to start with as a beginner.
  • »25.08.22 - 06:52
    beworld
    Posts: 664 from 2010/2/10
    @papio i use master branch from https://github.com/milkytracker/MilkyTracker to update MorphOS version. AmigaPort (MilkyTracker) is specific to AmigaOS3 or AmigaOS4.
    [ Edité par beworld 25.08.2022 - 11:55 ]
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »25.08.22 - 06:57
