Website Bugs
  • ASiegel
    Posts: 1387 from 2003/2/15
    This is the official MorphZone bug collection thread. Please post any issues you might find.
    Try to be concise. Please refrain from off-topic discussions. Do not post links to other topics.
    Thank you.
  • »15.07.12 - 06:24
    Posts: 2452 from 2003/2/24
    ASiegel,
    Pressing "quote" on a post just gives you this....
    The smilies underneath the textfield don't look like this:
     :-)  :-(  :-D  ;-)  :-o  8-)  :-?  :-P  :-x
  • »15.07.12 - 06:30
    boot_wb
    Posts: 874 from 2007/4/9
    After posting a reply to a post in a multi-page thread, the browser always redirects to page 1 of the thread, not the last page (or the page from which the 'reply' button was pressed).
    [ Edited by boot_wb 15.07.2012 - 10:58 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »15.07.12 - 08:58
    boot_wb
    Front page:
    "Show posts from last visit" function appears to be borked. Brings up posts from 2005 or so.
    Library:
    Would recommend adding a tree listing of the library showing current position, and 'next'/'prev'/'up' in all documents.
    Example - MUI Programming - The First steps:
    - Short BOOPSI Overview
    - Event Driven Programming, Notifications
    - "Hello world!" in MUI
    It would be logical to navigate to 'Short BOOPSI Overview', read that, and then progress to 'Event driven programming, Notifications' and subsequently 'Hello World'.
    Currently, one has to navigate back to index page to get to the 'next chapter' of the tutorial.
    Additionally, if a page is found via a search engine, or linked to directly, there is no way to see where in the library this lies, other related documents, or even what the parent docuement/chapter is.
    As the library fills, this will become much more of an issue.
    [ Edited by boot_wb 23.07.2012 - 15:16 ]
  • »23.07.12 - 13:16
  • ASiegel
    @ boot_wb
    Have you clicked on "Mark all forums as read" at least once?
    Library:
    This is really not what I would consider a technical "bug". For instance, Editors are free to use wiki categories and embed these in articles using "[Category: FancyCategoryName]. You are free to edit all articles accordingly. The tools are there.
  • »24.07.12 - 14:49
    Posts: 2726 from 2003/2/24
    I followed your advice here, but neither ordered nor unordered lists worked using BB code. It also broke the layout of the page. In the preview it didn't break the layout of the page, but the BB-tags [ ul ] / [ /ul ] and [ ol ] / [ /ol ] (minus the white spaces of course) was ignored and was printed out as plain text instead, and the li tags *on their own* generated bullet points in both the ul and ol lists.
    I then used the HTML code instead, this didn't break the design but the unordered list doesn't show bullet points, and the ordered list doesn't show numbers. However, with HTML everything worked as it should in the preview.
    (Edit: it was this thread I was talking about: https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11093&forum=3)
    [ Edited by takemehomegrandma 07.08.2015 - 22:14 ]
  • »26.02.15 - 23:13
    I posted a reply to "Kimmok"'s first post in this news thread:
    https://morph.zone/modules/news/article.php?storyid=2233&comment_id=8311&order=0#8311
    And then I made *a new* post (or so I thought) by typing into the box at the bottom of the comments thread (the "Quick reply" box?). The result was that my first post (the reply to Kimmok) was deleted, or rather "edited" with the second post.
  • »07.08.15 - 19:12
  • ASiegel
    @takemehomegrandma
    I have been able to reproduce the issue. It will be investigated.
  • »08.08.15 - 05:02
  • ASiegel
    The problem should no longer occur. Thanks for the report.
  • »08.08.15 - 05:26
    Posts: 15 from 2016/1/22
    I erroneously filed the bug report in a new topic, please see:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11541&forum=14
  • »25.01.16 - 22:10
    BSzili
    Posts: 561 from 2012/6/8
    When I'm trying to create a new topic in any sub-forum (for example in Development/SDK, I get this error:
    Error No: 0022
    Error Msg:
    An error ocurred while querying the database.
  • »10.03.20 - 13:37
    NewSense
    Posts: 1535 from 2012/11/9
    BSzili wrote: When I'm trying to create a new topic in any sub-forum [...] I get this error: Error No: 0022
    Error Msg: An error ocurred while querying the database.
    I've also reported/encountered that issue in the past, so let's hope it gets fixed soon.
  • »10.03.20 - 22:42
  • ASiegel
    @BSzili
    Would you mind trying again?
  • »11.03.20 - 05:20
    BSzili
    I tried it, but I got the same error.
  • »11.03.20 - 07:22
    Posts: 891 from 2003/3/4
    Broken link posting.
    For example
    http://amiga-news.de/de/news/AN-2022-07-00068-DE.html
    The "-" gets replaced by a smiley face and the link breaks. Adding it using the url= code completely breaks it:
    Like this
    Appears to work in preview with smileys switched off, but when posted it's broken.
    Yes, I'm aware you said not to link to other topics, but in this case I have to, to make you aware of the actual problem.
  • »22.07.22 - 21:09
    Posts: 12408 from 2003/5/22
    Actually, it's '8-D' that is interpreted as smiley with "Enable Smileys" ticked and thus gets replaced.
  • »22.07.22 - 22:12
    It still happens with Enable Smileys not ticked, like I said.
  • »23.07.22 - 07:52
    And since I know exactly what you're going to reply, yes the preview is correct when you do so. The post however is not.
  • »23.07.22 - 07:54
    I just intended to correct you on the character(s) that get replaced. If it really was "-", it would be two independent bugs at work.
  • »23.07.22 - 12:29
    You clearly don't :-P
  • »23.07.22 - 12:31
    You spamming the thread and adding nothing of value or addressing the bug?
    Glad to see that wasn't the case eh?
  • »23.07.22 - 12:36
    No, the claim was my potential reply being refuted by "the preview [being] correct when you do so. The post however is not.", which is nothing my actual reply was about. I may not have addressed the bug, but clarifying that there's no second bug at work (which would have been the case with "-" getting replaced) may be considered of value.
  • »23.07.22 - 18:09
    connor
    Posts: 650 from 2007/7/29
    Sometimes the text breaks out of the text area, e.g. https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=13850&post_id=160291&viewmode=flat&sortorder=0&showonepost=1 and https://morph.zone/modules/newbb_plus/viewtopic.php?forum=10&topic_id=13806&post_id=160494&viewmode=flat&sortorder=0&showonepost=1 . The text is dificult to read then what is the original text (quote), what is the new one. And then the grey bottom line is cut off, has a black dot and the comment nombers are half on the side of the box. Can someone fix the layout?
  • »17.12.24 - 13:42
    connor
    Oh, I get a horizontal slider oin my comment! Firs t time ever on this forum.
  • »17.12.24 - 13:43
