AmigaOS 4.1 Fonts in MOS 3.15 ?
    LuckyHazlenut
    Posts: 8 from 2021/4/6
    Does anyone know whether the TTF fonts from the AmigaOS 4.1 can be used in Morphos?
    iMac G5 2.1 20" iSight (PowerMac 12.1)
    Registered MorphOS 3.15 since
    -- (11.04.2021 - 23:30) --
  • »20.07.21 - 18:16
    Posts: 2491 from 2003/3/5
    No idea what its EULA has to say, but there should be no reason why any TTF files couldn't be installed on MorphOS.
    You'll likely need to install them with FT2 and TTE Manager apps for them to be visible to all apps.
  • »20.07.21 - 19:53
    LuckyHazlenut
    Where can i Download the FT2 and TTE Manager apps ?
    Thank u jacadcaps
  • »21.07.21 - 11:00
    Templario
    Posts: 415 from 2012/4/28
    TTEManager is in System:Tools
  • »21.07.21 - 12:00
    Posts: 11438 from 2003/5/22
    ...as is FTManager.
  • »27.07.21 - 18:04
