Reset Network prefs
    Posts: 2165 from 2003/2/24
    I'd try with these files:
    SYS:Prefs/Env-Archive/sys/interface.prefs
    SYS:Prefs/Env-Archive/sys/interfaces
    The "interfaces" file is editable plain text if that's enough? If that doesn't help removing/renaming the files should reset everything to default I guess.
    [ Edited by jPV 12.06.2021 - 16:26 ]
  • »12.06.21 - 11:25
