Youtube
    Posts: 891 from 2003/3/4
    > It will eventually break unless someone is spending their time
    > constantly working around Google's changes.
    That's what was happening for the last 15 years, with a large amount of people in the role of this "someone", and also in a platform-agnostic way with scripts written in Python, Lua, JavaScript etc. I'm confident this will last as long as YouTube does :-)
    Nah. Sooner or later they'll lock it down. Remember all those open source streaming devices and third party YT viewing apps of the 00s? Google shoved those right out of the market.
    It's in Google's interest to forcefeed you those ads and track your usage. They will eventually find a way to block direct url streaming through anything but approved devices. It doesn't need to be cast iron tight like some kind of DRM, just as long as it makes it imponderously inconvenient, and that'll be enough. Those url extraction tools seem to get bigger and slower every release.
    [ Edited by KennyR 03.07.2020 - 23:42 ]
  • »03.07.20 - 20:37
    Posts: 3216 from 2003/3/5
    They don't really have a choice if they want to be able to download HLS streams - you need to be able to remux those into a single file...
  • »03.07.20 - 21:13
    redrumloa
    Posts: 1424 from 2003/4/13
    ASiegel wrote:
    An updated version of the "YouTube_FullScreen_Fix" user script can be found here:
    http://morph.zone/downloads/YouTube_Fullscreen_Fix.zip
    This adds support for the mobile version of YouTube.
    For users who had the old script enabled previously and overwrote their copy with the updated version, you might have to manually add
    https://m.youtube.com/*
    to the list of affected URLs in the "Scripts" window.
    If anybody keeps getting forwarded to the desktop version of YouTube, try visiting this link: m.youtube.com/?persist_app=1&app=m
    Thank you kindly for this. I'll try it out later today.
  • »04.07.20 - 15:51
    redrumloa
    This works extremely well. Dare I say better than before? Spoofing as Ipad with this new script is great! Low CPU load!
  • »05.07.20 - 23:35
    Doffo
    Posts: 508 from 2010/10/14
    Good to hear!!
    YUUUP!
  • »06.07.20 - 00:53
    Posts: 1335 from 2004/2/8
    Sadly it doesn't work for me at all. If I go fullscreen then I all I can see is a black screen.
  • »06.07.20 - 11:32
  • ASiegel
    Posts: 1387 from 2003/2/15
    @koszer
    Sounds like a graphics driver issue.
    What happens when you use other applications that utilize overlay? Have you tried to play a "plain" HTML5 sample video file (link: example) in fullscreen?
  • »06.07.20 - 12:16
    ASiegel wrote:
    @koszer
    Oooops - black screen too - I can only hear the sound. That's very sad to hear as I did recently switch from Apple Radeon X850XT to PC Radeon X1950GT. It should do overlay just fine, shouldn't it?
  • »06.07.20 - 13:06
    redrumloa
    I didn't have an issue with my PC X1950 Pro. Not sure how much different the GT version is to the pro.
  • »06.07.20 - 19:10
    sabbate
    Posts: 110 from 2013/7/7
    also on aros don't works
  • »07.07.20 - 13:15
  • ASiegel
    @sabbate
    This discussion is about solving issues related to YouTube on MorphOS.
    AROS uses a different Webkit version. As far as I can tell, it cannot even display the mobile version of Youtube properly - unlike Odyssey on MorphOS. Feel free to open a new topic in our "Off Topic" forum if you would like to discuss Odyssey on AROS further.
  • »08.07.20 - 07:23
    So it seems I shoud either find myself another gfx card (1950 Pro?) and go from there or report a bug through MorphOS bugtracker (or both)?
  • »08.07.20 - 07:31
    sabbate
    ok asiegel
    I just wanted to report this thing, since we are also talking about OS4, however once someone had created a script on aros when odyssey still did not have the html player which is cross-platform called youtubedl, I close the intervention here
  • »08.07.20 - 09:54
    Posts: 12408 from 2003/5/22
    See comment #41 :-)
  • »08.07.20 - 10:20
