x800xt ... or, best 7,3 GPU?
  • esc
    esc
    Posts: 160 from 2013/5/27
    Hey folks,
    I have a powermac 7,3 and would prefer running the most powerful and fully supported GPU for both osx and morphos. Obviously linux is a wildcard here but having linux support would be great...but I'm not holding my breath for true 3d acceleration :)
    I think the ati x800 xt is the ideal card for this, but it seems to be rarer than hen's teeth. Can anyone recommend a good path here? What would be "best" supported out of what I might be able to find?
    Thanks!
  • »11.06.20 - 15:28
    ernsteiswuerfel
    Posts: 568 from 2015/6/17
    I had a flashed FireGL X3 on my G5 7,3 which translates to a X800 XT. It worked fine on MorphOS and I tried it one time on OS X where it worked too. It did however not work on Linux where it locked up the machine. I replaced it with a Radeon 9800 Pro (original Mac-BIOS) which worked on Linux, albeith rather slow.
    Don't know if this is a 'flashed card issue' or the X800 XT by itself won't work on Linux. Is there any AGP X800 with original Mac-BIOS?
    PMac G5 11,2. PMac G4 3,6. PBook G4 5,8. [MorphOS 3.19 / Adelie Linux / Gentoo Linux] | A600GS [Amibench / OS 3.2] | Talos II Secure Workstation. [Gentoo Linux]
  • »11.06.20 - 17:14
    Posts: 1335 from 2004/2/8
    Yep. I got one. But precisely - it's X850XT. It's got both DVI and ADC connectors and it's AGP Pro type card. Looks like that:
    When it comes to MorphOS performance the X1950 beats it. But it's quite unlikely that X1950 will work with OSX (I don't think there's a suitable Apple ROM for an AGP card).
  • »11.06.20 - 18:23
    ernsteiswuerfel
    Nice! And what's the state of Mac-BIOS X800X/X850XT performance on Linux? Just curious if they do run it and how well they fare. ;-) Not that I could try it, sold my G5 7,3 some time ago.
  • »11.06.20 - 20:56
    redrumloa
    Posts: 1424 from 2003/4/13
    esc wrote:
    Hey folks,
    Thanks!
    If you you give up OSX, the X1950 line (PC AGP version) is a pretty big step up. That is the fastest.
  • »11.06.20 - 21:29
  • esc
    esc
    Sadly I need OSX for all the DAW stuff on it. :/
    I can't really find any decent AGP Mac GPUs. Guess I just have to stick with what I have.
  • »11.06.20 - 23:35
    Posts: 12408 from 2003/5/22
    The X850XT seems to be available at some places if you search for its Apple PN (it's in comment #10 of the thread I linked to in comment #4). Prices are another matter, though.
  • »12.06.20 - 05:20
  • esc
    esc
    Thanks. I did actually find a few sites claiming to carry surplus apple kit but they all seem just a bit dubious. I tried ordering from one of them (can’t remember which) and it took them a week to refund me the money saying they didn’t have it. Nevertheless I’ll see if I can find anything. Thanks, Andreas_Wolf.
  • »12.06.20 - 13:26
