PowerBook faulty key
    tolkien
    Posts: 550 from 2013/5/29
    Hello.
    I have a PowerBook g4 15" a1106. I used it daily but recently the "r" key doesnt work.
    Dont know how to fix it bit I think I'll buy a second PowerBook to change the keyboard.
    Do you know if there are more PowerBook models compatible with this keyboard.
    Damn powerbooks...this is my second one is failing..
  • »08.06.20 - 18:53
    Posts: 1335 from 2004/2/8
    tolkien wrote:
    Hello.
    I'd just lift the keycap and check if some cleaning does the trick.
    I believe it's Apple part number 922-6593 (A1106 and A1107 compatible).
    EDIT: Let me check my "PowerBook spare parts box" to see if I have any of those...
    [ Edited by koszer 09.06.2020 - 13:28 ]
  • »08.06.20 - 19:34
    tolkien
    That was the first thing I did without luck.
    mmmm...my last PowerBook was a g4 17". Dont know if it is an a1107 but I think I still have it somewhere.
    Would be nice if it is compatible.
    Thanks so much Koszer!
  • »09.06.20 - 14:46
    I guess I've found the A1106 topcase in my spare parts box. The keyboard has got Swedish layout (or so) and I'm not sure if it's 100% working, but it should be OK. I can send it to you just for the shipping costs if you fail to find a proper one yourself.
  • »09.06.20 - 15:31
    tolkien
    Will try to search my old PowerBook this weekend. If It doesn't work perhaps I have to accept your offer. I'll write here.
    Thanks so muchos koszer.
  • »10.06.20 - 19:49
    Posts: 891 from 2003/3/4
    If I remember right, the PPC PB has exactly the same key structure as most laptops: two metal wire squares as springs and a little rubber pad. If you're very careful you can take the key off, clean the circuit board contact with a bit of alcohol, and carefully clip it all back on.
    Last time I tried to do this with a laptop, the key just broke off permanently, so beware. I hate laptop keyboards.
  • »10.06.20 - 20:14
    NewSense
    Posts: 1535 from 2012/11/9
    The PowerBook keyboard has a multi-layered contact membrane that is folded back onto itself, as in its a double width membrane, but with contacts that extend past/through/onto the folded section and under/over the 2nd layer, if I remember correctly
    It is an almost impossible task to repair the membrane contacts as they are silver coated lines that are laid onto the clear keyboard membranes like painted lines. The membranes are extremely thin, and look like 1 layer, but if you are extremely careful you can peel them apart, but the danger is of the 'silvering' being damaged, possibly irrepairably as you separate the layers. Sometimes warming the membranes can allow the adhesive holding the layers together to come apart more easily, and without being too destructive to the surface layers. Additionally, over time, and liquid spills onto/between the metal layers the silver paint gets contaminated, burnt-out, deteriorates or flakes off, stopping the keypress making its contact.
    You can use windscreen re-silvering paint (usually for heated rear windscreens repair) to 'paint' in the gaps/lines/on and between the keypress contacts and get some keyboards working again, which I have done a few times successfully. However, it's a time consuming and unreliable task, but if you've no other means of repair, or want to try that first then give it a go.
  • »11.06.20 - 02:16
