Real Time Clock losing time quickly
    Posts: 79 from 2020/5/1
    Hardware: Sam460ex 1150 MHz reported by MorhpOS as 1265 MHz.
    1. Is the clock drifting due to the wrong cpu frequency reported, or is it just a bad battery? Something else?
    2. Synching clock against time server works as expected, but how often does it sync automatically (if at all)?
  • »11.05.20 - 20:26
    Posts: 2159 from 2003/2/24
    2) I don't think it syncs frequently during the session at all, it just syncs when commanded. But you can add, for example, this kind of line to your S:user-network-startup file:
    Run >NIL: WaitX M=60 ALWAYS CMDLINE "C:SetClockNTP"
    Replace the minute value for the M argument for what you feel is required. Or use H= for hours. Then it repeatedly syncs the clock in the background.
  • »12.05.20 - 03:24
    Posts: 891 from 2003/3/4
    Change the battery anyway.
  • »12.05.20 - 09:59
    Thanks, just what I was looking for.
  • »12.05.20 - 11:36
    If you check the NTP server too many times per hour, they have been known to block you. Fair warning.
  • »12.05.20 - 17:54
    Good point. Once per hour is hopefully okay, and it's not like I keep the machine running all around the clock.
  • »12.05.20 - 18:08
    Posts: 1060 from 2004/9/23
    The default time servers are AFAIR pooled, so you probably get a random one at anytime. There are also three different pools build in and you can specify a server if needed.
    But right there is no use to abuse their free service anyway.
    If our systems are on for about 12 hours a day the time diff should only be a few seconds and only on the condition of having not a single reboot.
  • »12.05.20 - 18:24
