Help with WHDLopener
    retroPete
    Posts: 6 from 2006/3/20
    Hi!
    Is anyone able to help me installing the WHDLopener kit I downloaded?
    I guess I'm missing some sorts of components, but the installer says something about the space?! Although there is plenty of rom left.
  • »19.07.19 - 19:20
    Korni
    Posts: 471 from 2006/2/23
    Space as a character (made by the spacebar key on a keyboard), not storage space. For now, you can't install when destination path contains a space. Will it be fixed? Maybe.
  • »19.07.19 - 21:32
    retroPete
    Thanks for the replys!
    Well the problem is that whatever destination I choose it still complains about the space..
    Tried several times and different places but always the same result..
  • »20.07.19 - 10:12
    Korni
    WHDLOpener installs fine on a clean MorphOS + SDK.
    Do you use installer, sed and pathpart supplied by MorphOS? If not tell me versions.
  • »20.07.19 - 10:47
    retroPete
    I did a fresh install yesterday and as well installed the MorphOs SDK package. Nothing else.
    Just can't get it to work anyhow :(
  • »20.07.19 - 13:56
    Korni
    Just to be clear. Does it show "Space in path suxx!" message? When it displays this, can you tell me what's inside T:WHD/SPACECHECK and SPACECHECK2?
    Or is it "To install the WHDLOpener package into '%s', you need at least %ld MB of free space!" ?
  • »20.07.19 - 14:49
    retroPete
    Well thanks for all the responses!
    I tried another fresh install of MorphOS and the SDK package.
    I can now continue the installation =)
    Is there any sort of gui for the e-uae, for easy configurations? I'm more used to the win-uae version.
  • »21.07.19 - 16:57
    Brunty
    Posts: 11 from 2019/8/10
    I'm suffering here too!
    On the installation I receive the error "Space in path suxx!"
    I get this error even if I just click continue without selecting a path (using the default SYS:).
    Fairly vanilla install of MorphOS etc.
  • »22.09.19 - 10:35
    Korni
    Hello Brunty,
    Open a new shell window, paste this and tell me the output:
    Version
    Version C:Installer C:PathPart echo
    sed --version
    When "Space in path suxx!" error is displayed:
    Type T:WHD/SPACECHECK
    Type T:WHD/SPACECHECK2
  • »22.09.19 - 11:56
    Brunty
    Korni wrote:
    Hello Brunty,
    Version
    sed --version
    Hi Korni
    output as follows...
    System:> Version
    MorphOS 3.11, Ambient 1.44, Kickstart 51.40
    System:> Version C:Installer C:PathPart echo
    Installer 1.39
    PathPart 52.0
    shellcmd 51.3
    System:> version c:sed
    SED 40.3
    System:> Type T:WHD/SPACECHECK
    '"DH2:"'
    System:> Type T:WHD/SPACECHECK2
    DH2:
    Cheers,
    Brunty
  • »22.09.19 - 14:11
    Brunty
    Fantastic!
    Thanks very much for your help :D
  • »22.09.19 - 17:03
    Brunty
    I have another quick question, if I may?
    Is it possible to run multiple disk programs?
  • »16.11.19 - 09:06
