Kickstarter: Tower 57 for MorphOS
    beworld
    Posts: 590 from 2010/2/10
    Excellent game :-)
    Volume (sound & music) are very low....
    IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
    My MOS ports
  • »13.03.18 - 18:04
    Posts: 564 from 2004/4/15
    Yes, just played it on my Mac mini.
    This game is a really good reason to start my MorphOs machine again ;)
    Well done Daniel, it runs really smooth.
    @all: Buy this game if you like Chaos Engine like games, it's really great!
    [ Editiert durch eliot 13.03.2018 - 18:32 ]
  • »13.03.18 - 18:27
    asrael22
    Posts: 404 from 2014/6/11
    Where to buy it?
  • »13.03.18 - 18:50
    asrael22 schrieb:
    Where to buy it?
    https://benitosub.itch.io/tower-57
  • »13.03.18 - 19:28
    Debaser
    Posts: 161 from 2005/7/12
    I just purchased it and gave it a quick play. Fun game and very well done. :) Very cool!
  • »14.03.18 - 16:04
    Adonay
    Posts: 17 from 2015/8/7
    Just bought this will be fun .
    Edit*
    Sound FX and music is very low
    [ Edited by Adonay 15.03.2018 - 10:23 ]
  • »14.03.18 - 22:17
    defender
    Posts: 247 from 2011/4/24
    Just bought and tried tower57. Not my kind of game but it looks great. Thank you, Daniel!
  • »15.03.18 - 21:16
    danwood
    Posts: 95 from 2009/10/5
    I recorded a quick video showing the MorphOS version today:
    https://youtu.be/khueCD7qmIw
    [ Edited by danwood 15.03.2018 - 21:08 ]
  • »15.03.18 - 22:04
    WeiXing3D
    Posts: 327 from 2012/6/13
    I'm geting message saying that I need ixemul library 57.00
    Where can I find it, and where to install it once downloaded?
  • »16.03.18 - 04:32
    ixemul library 57.00 is part of the MorphOs SDK.
    Download is fro here: http://morphos.de/files/sdk-20160605.lha
  • »16.03.18 - 06:41
    beworld
    Edit*
    Same here when i launch "Launch.Exe" but click on Tower57_MOS and sound working fine..
    I play some time on this game, very cool, but i block at the end of the Boss "Workshop"....
    My MOS ports
  • »16.03.18 - 07:10
    Posts: 12077 from 2003/5/22
    System libraries belong to MOSSYS:Libs/
  • »16.03.18 - 16:16
    Unfortunately, it only contains v50.17 ;-)
  • »16.03.18 - 16:17
    beworld
    How to player with Joypad or 2 players :-) ??? i trying but doesnt work ?
    Anyone have try ?
    My MOS ports
  • »16.03.18 - 17:37
    Posts: 779 from 2007/10/23
    Anyone have try ?
    Me too!
    The gameplay defaults to the controller you have been using in the menu - if you have a controller plugged in but choose “New Game” or “Continue” in the main menu using keyboard, you won’t be able to play the game using the gamepad. In order to do so, please quit to the main menu and load the game/start new game using the joypad to select an option.
    Huh?
  • »17.03.18 - 01:29
    TheMagicM
    Posts: 1217 from 2003/6/17
    Yeeeaaahh.. Those instructions for joystick control dont work for me. My joystick is recognized by Posiedon but in the game, nothing.
  • »17.03.18 - 15:14
  • MDW
    MDW
    Posts: 453 from 2003/7/26
    I have already bought "Tower 57" and run on my PowerBookG4 with MorphOS 3.9. Game looks well, works well and fast on window and fullscreen 1440x960 24-bit and 16-bit. However in 24-bit mode I see strange artifacts - blinking short horizontal lines. In 16-bit mode there are no artifacts and game looks great.
    Does someone know what is reason of the problem? In MorphOS Monitor Preferencs I have standard "Color LCD" and on test screen 1440x960 24-bit the artifacts are not visible. On my Ambient (1440x960 24-bit) these artifacts also don't occur.
    [ Edited by MDW 17.03.2018 - 23:10 ]
  • »17.03.18 - 22:50
    @MDW
    Please send a screenshot to tower57@goldencode.de
    [ Editiert durch polluks 18.03.2018 - 17:57 ]
  • »18.03.18 - 17:46
  • MDW
    MDW
    polluks wrote:
    @MDW
    Do you have a screenshot?
    I made several screenshot but the artifacts are not visible on screenshots. :) Everything looks very good on screeshots. However on screen I see these short horizontal blinking lines.
    I notices something interesting. If I run "Tower 57" on 24-bit screen and switch to Ambient screen, these lines are visible on Ambient too. If I close game, Ambient looks good again.
    Is it a hardware problem of my PowerBookG4? Why the problem occurs only if I launch "Tower 57"?
    [ Edited by MDW 18.03.2018 - 18:09 ]
  • »18.03.18 - 18:04
    BSzili
    Posts: 559 from 2012/6/8
    That sounds like some kind of hw/driver issue.
  • »18.03.18 - 19:45
    Posts: 2972 from 2003/3/5
    It’s a driver issue.
  • »18.03.18 - 22:45
  • MDW
    MDW
    Thank you for the info. Is it known issue? So I won't try to fix it. :)
    Do you know if the the issue occurs on MorphOS 3.10?
  • »19.03.18 - 09:00
  • MDW
    MDW
    I have just updated MorphOS to 3.10 (PowerBookG4/1,67) and... the artifacts gone! Tower57 works on 1440x960 24-bit works great.
    Thank you MOSTeam for update drivers! :)
  • »25.03.18 - 20:26
    Cool_amigaN
    Posts: 746 from 2011/11/30
    Hey, just bought the game, unzipped, clicked launch nothing happens. Clicking the 2 Tower 57 executables on the sub folder doesn't do anything as well.
    Snoopium reports that Background CLI [shellppc.prefs] and updater_mos [IXPPCSTACK] both fail (from the executable of the sub folders). On the main launcher additionally C:IconX window/stack/usershell/wait/delay fails. This is on MorphOS 3.9. Any ideas?
  • »22.06.18 - 19:35
