Posts: 590 from 2010/2/10
hi,
i put my source code of Rockbot (1.0RC1 or 1.1.1), (same bug in 2.0 version)
I have a big problem with SDL (i think....), mistake some graphic in game playn and no sprites enemy....
i see no error, need help
(i try to change parameters of SDL_Setvideomode... but nothing change)
If any developer can try to find the bug or recompile to see if same problem.
in lha file, you find the binary (compile with GCC 5.3, last powerSDL under MOS 3.9 SDK3.10), you can test it...
rockbot1rc1.pngMy SourceYou can find Windows/Linux etc... version and source to test :
http://rockbot.upperland.net/?page_id=901
thanks you
BeWorld
IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
My MOS ports
