CountRaven wrote:
Really?
Dealing with the Chinese is hit or miss.
I know people who have received perfectly useful items from that company and others that have received fakes (like an exploding 'op amps' for instance).
The more obscure the part, the less likely it is that it might be real.
BUT, that doesn't mean that it might not be.
Also, a lot of the parts they sell are salvaged components.
I'm pretty sure what you are looking at is a BGA (ball grid array).
Instead of plain pins, these surface mount components have small balls of solder at each connection point that is melted in a temperature controlled environment when surface mounting.
A salvaged BGA doesn't have solder balls.
Sometimes these can be re-balled though.
I would try to find someone with a surface mount re-work station before you try to replace that part and just get them to re-flow the solder connections under it.
That might take care of your problem.
I'd hate to see a Peg fail to function.
There aren't that many of them.
