A bounty for tutorials videos MorphOS
  • ASiegel
    Posts: 1386 from 2003/2/15
    If there were more tutorial videos about MorphOS, that would be great.
    That being said, before you ask the community for financial contributions, why not ask whether anybody knows more affordable options or whether anybody has appropriate hardware and is willing to donate that instead?
    350 EUR seems pretty steep for what you are trying do do. Is it absolutely necessary for you to use a USB-based solution for this? If you search for "AVERMEDIA" on the Ebay France website, you should find PCI cards that cost well below half of what is charged for the Avio model. On Ebay Germany, brand new Avermedia cards can be bought for less than 100 EUR and there seem to be a number of auctions with few bids and low starting bids as well. (USB-based offerings from StarTech are a bit more expensive but at prices between 160 and 200 EUR still much more affordable than the Avio option.)
    [ Edited by ASiegel 26.08.2015 - 05:41 ]
  • »26.08.15 - 02:36
    Posts: 1059 from 2004/9/23
    I would go for the Haupauge PVR Rocket, which does the same for far less money.
    http://www.amazon.de/Hauppauge-01527-HD-PVR-Rocket/dp/B00GC3Z6GM/ref=sr_1_1?ie=UTF8&qid=1440575271&sr=8-1&keywords=pvr+rocket
  • »26.08.15 - 05:49
    Tcheko
    Posts: 539 from 2003/2/25
    @geit +1. Good enough for the purpose. No need for 1080p@60fps recording at all.
  • »26.08.15 - 06:08
    Yasu
    Posts: 1724 from 2012/3/22
    Who will do the voice? Several similar projects have been destroyed because the voice is not good enough.
    My MorphOS blog
  • »26.08.15 - 17:25
  • ASiegel
    One could always provide optional subtitles if this was a serious issue. (Google´s YouTube can even try to create those automatically although one might have to improve the automatic transcript a bit.)
    Plus, I do not think the idea is to produce hour-long tutorial videos but rather short and concise clips, which should make it a lot more tolerable to listen to a voice that you happen to dislike.
    @ Papiosaur
    If you create a separate YouTube channel for your videos, it should be easy to integrate them on other websites.
  • »27.08.15 - 05:17
