Booting from SCSI
    Posts: 8 from 2004/2/27
    Anyone experiences with booting MOS from SCSI HD?
    I can see my SCSI HD in OF, I can see the partitions I made with MOS, I even can listing the files on the Harddrive. But booting works MOST of the time NOT!
    I have a PEGII/G4/512MB/QuantumAtlas10kIII/DawiControlUW-Controller/Radeon7500
    SCSI-Termination should be correct. Tried different cable, ID-settings...
    Booting from CDROM works correct, but needs very long to get to the butterfly-screen. When SCSI HD is not wired, then booting from CDROM is much faster. What is MOS doing after the "rotaing star" and before the butterfly appears?
    Sometimes, I cannot figure out when, perhapes the weather?, MOS IS booting from HD.
    byby
    KIKI
  • »27.02.04 - 20:46
    magnetic
    Posts: 2129 from 2003/3/1
    What type of SCSI card are u using. Be very specific - manufacturer, chipset etc..
    magnetic
  • »27.02.04 - 21:45
    It's a DC-2976 UW from Dawicontrol based on the 53C875 chip.
    byby
    KIKI
  • »28.02.04 - 02:39
    magnetic
    There is your problem.. 875 is bRoKEN atm... :(
    try 825 or 810 and 895 maybe
    mag
  • »28.02.04 - 03:49
    What do you mean with broken? It's on the hardware compatibility list of MOS!
    Must I really buy another one?
    byby
    KIKI
  • »28.02.04 - 07:17
    downix
    Posts: 105 from 2003/2/10
    The 875 works.... sometimes. Apparently Symbios/LSI had different versions of it but labelled them the same, so some chips work out of the box, some don't.
    Sorry.
    Nate Downes
    Genesi SARL
  • »28.02.04 - 16:35
    Golem
    Posts: 766 from 2003/2/28
    Will this be fixed? Or will the hardware compatibility list be updated to reflect the current status?
  • »28.02.04 - 17:20
