Linux on PegII.
    liquidbit
    Posts: 407 from 2003/10/12
    Hi, Im planning to install Linux as dual boot in my pegII.
    Where can I find the best instructions on the web and a Bootable cdrom (ISO image) ?
  • »23.02.04 - 15:28
    magnetic
    Posts: 2129 from 2003/3/1
    Best bet for you is to go to linux.pegasosppc.com and research info there. There is also a bootloader where you can do a linux net install..
    magnetic
  • »23.02.04 - 15:50
    Posts: 261 from 2003/3/13
    The net install still doesn't work with Debian.
    Felix.
  • »23.02.04 - 16:02
    liquidbit
    ...Idont want to install it through the network, I just want a boot ISO CD...
  • »23.02.04 - 16:15
    magnetic
    Felix:
    ATM the net installer is broken we are working on it.
    For install with Cd rom and other infos please go to the pegasos linux website..
    magnetic
  • »23.02.04 - 17:53
    liquidbit
    ..I just see image installers for Pegasos..are they compatible with PegasosII ?
  • »23.02.04 - 20:57
    magnetic
    NO
    Tomorrow new installer will be up.
    Liquidbit join linux.pegasosppc.com for more infos
  • »23.02.04 - 22:05
    liquidbit
    Thanks magnetic, I will.
  • »23.02.04 - 22:09
    ultraspec
    Posts: 94 from 2004/1/29
    I've been putting some extra info about Linux installation and configuration on my PegasosComputer Wiki
    Mostly has info about Debian, and answers to some common q's I have come across (how to get sound working, mol, etc).
    I just started trying out Gentoo as well. Successfully installed that and am fooling around with the build system.
  • »24.02.04 - 16:40
    liquidbit
    ultraspec that you did is really cool!
    It is great when you test something new with your computer to make some documentation after, the most people forget to do that last part.
    I will say it one more time...A good documentation save others time!!!
    I dont want to step in the same problems like the last hundred users did.
    I don't say that the Pegasos Linux Community is bad, but it has to stay up to date.
  • »24.02.04 - 17:22
  • mat
    mat
    Posts: 23 from 2003/10/22
    And I don't want to be defending anyone, but could you tell me what should I document about working system? I do understand troubleshooting, and this is done on PLC. But after the problem is found (and usually fixed or remedied in some other way) it is documented in the forum and then... What else to write? It's just Linux after all ;-)
    M.
  • »25.02.04 - 07:34
    liquidbit
    Well ..I think the whole solution should be published in the first page of the PLC ?
    Two Instruction Documents?
    One for PegasosI(already exists) and second one for PegasosII ???
    ..do I ask much?
  • »25.02.04 - 10:52
  • mat
    mat
    liquidbit wrote:
    ..do I ask much?
    Well... I don't know if it's too much. But my answer is - if you want to install Gentoo (as I did) read installation manual (there is link from PLC to David's page where you can find everything that you need) and follow it. It should work without any problems if you have "standard" hardware setup. If not - then how can anyone know what problems might have been occured to you? You just have to ask.
    The only thing I think is missing (from my, Gentoo-centric, point of wiew) is some FAQ with most comon problems explanations - all (or most) of them explained in PLC forum.
    And if you really want to install any other distribution then you'll have to ask someone who use it - in this case you may be right and there may not be enough documentation.
    M.
  • »25.02.04 - 12:17
    ultraspec
    Thank you for the positive comments :)
    The Gentoo installation docs were pretty good. I got the base system installed and running without any problems... still working on a few things. Installing on Pegasos hardware is not much different from other systems, you just need some patience :) and make sure the boot images (and any custom kernels you may build) will work on Pegasos.
    Keep a known working boot image on your boot partition so you can always get the machine booted in case of a mistake.
  • »26.02.04 - 17:46
    liquidbit
    I tried..
    Debian
    Gentoo
    Mandrake
    Results: No success
    The image installer is trying to install linux through the cd instead the internet...
    Gentoo does not recognise my Videocard (Radeon 8500) and so on.
    ..thats my first touch with LinuxPPC world.
    I'm using in my i386 systems, Red Hat 7 & Mandrake 9.2 (for the people who think that I'm totally n00b).
  • »27.02.04 - 15:35
    mahen
    Posts: 118 from 2003/2/24
    liquidbit : there's a new linux install image on linux.pegasosppc.com since... today, it solves this issue. Here it worked for me. Okay, now I've to configure xfree for my voodoo :)
    xmpp:mahen on jabber.fr
  • »27.02.04 - 16:01
    liquidbit
    ..i just saw it ...im testing it !!!
    [Edit]
    after install the bios does not recognise ext3 partition
    [Edit]
  • »27.02.04 - 16:11
  • mat
    mat
    liquidbit : You seem to have strange problems. And it sound even stranger to me when you say you have at least some experience with Linux (well - maybe the distribution choice is not the best, but it's Linux after all ;-)).
    I can't help you with the other distros, but could you please tell me what is the effect of your videocard not beeing recognized by Gentoo? In which stage - is it during boot or maybe later in X? If it's during boot process please give the exact commandline you enter at the OF prompt to boot the Gentoo install kernel. If your card is standard AGP Radeon, then there should be absolutely no problems with it. It just have to work.
    M.
  • »27.02.04 - 17:24
