Which language do I use?
    asrael22
    Posts: 404 from 2014/6/11
    Hello there.
    I'm glad to see that my old iBook and PowerBook can be of some more use with MorphOS.
    For a house automation project of mine I thought I'd like to revive my old AmigaOS enthusiasm and use MorphOS on an iBook for it.
    I've got enough of C/C++ and would like to use AmigaE, PortablE or AmiBlitz (or something else which can do the job).
    Now the question: can those languages (or runtimes) use the Poseidon USB stack as well as the TCP/IP stack?
    Regards,
    Manfred
  • »11.06.14 - 07:29
    asrael22
    Hmm, sorry. For some reason I couldn't post to the "Developer" forum.
    Although the question is not completely wrong here.
    Manfred
  • »11.06.14 - 07:30
    Posts: 3210 from 2003/3/5
    PortablE should be able to use these.
  • »11.06.14 - 09:47
    Posts: 826 from 2007/10/23
    You can use any language which supports Exec device and library calls, I recommend ECX.
  • »11.06.14 - 10:10
    asrael22
    Why do you recommend ECX over PortablE?
    Manfred
  • »11.06.14 - 12:41
    You don't need any linker or libraries, just the compiler and the modules.
  • »11.06.14 - 13:45
    Yasu
    Posts: 1724 from 2012/3/22
    @asrael22
    The latest version of PortablE isn't finished yet, and the beta has bugs on MorphOS. I'm waiting for a working new version myself.
    My MorphOS blog
  • »11.06.14 - 19:51
