Posts: 888 from 2004/1/24
Ah, time for some questions again:
1. Worthworth 6
I know that it should work, because it is listed as working in the compatibility list BUT according to the same list you should edit the tooltype PICASSO=TRUE (easy) and "CGX-settings ForceChunky=0"....come again? Anyone?
2. Digiboosterpro 2.21
Copied the reqtools and the iffparse library to libs: but still, the program hangs when loaded. Everything looks ok, but the busy pointer ,err, stays busy and no button works...and in a few second morphos won't react anymore :(
3. Quake2
Not the hyperion version but the "Frank Menzel" version. Won't start because it cannot find "pics/colormap.pcx". Is there someone who got this version running?
4. SHOGO demo
Configuration screen works, but hangs when I try to launch the game
many thanx in advance,
