PuhDerBear: Paula to AHI re-director for MorphOS?
    Samurai_Crow
    Posts: 153 from 2009/12/10
    When OctaMed SoundStudio was first attempted on AOS 4.0 prereleases (before the Maestrix was written in closed-source AmigaE) they discovered that it required a CIA timer as well as Paula emulation. There was eventually a patch for that too called CIAgent but I think it was closed source as well.
    edit
    Since we know that the Maestrix is written in AmigaE as a commodity, it might be easier to patch the stack swapping code that this 68k binary contains. PPC needs a bigger stack than a 68k even when emulating 68k.
    [ Edited by Samurai_Crow 17.08.2014 - 17:00 ]
  • »18.08.14 - 02:51
    Posts: 1516 from 2003/2/24
    In MorphOS PPC stack is automatically set to 32 kB which is the minimum.
  • »18.08.14 - 04:31
    Spihunter
    Posts: 84 from 2003/7/10
    I would donate to a bounty to just have Octamed SS patched.
    17" Powerbook. MorphOS registered
    Hear my music here: Gordon Gallant
    And here: Kattalax
  • »18.08.14 - 13:05
    pampers
    Posts: 1061 from 2009/2/26
    Pete wrote:
    That's great news! Thank-you and I hope very much that it comes to fruition.
    Unfortunatelly won't happen anytime soon. In the mean time why not to use EUAE with JIT ;)
    MorphOS 3.x
  • »20.08.14 - 12:53
    redrumloa
    Posts: 1424 from 2003/4/13
    14 months later, we cooking with grease? ;-)
  • »09.10.15 - 23:00
    Intuition
    Posts: 1110 from 2013/5/24
    pampers wrote:
    Pete wrote:
    Hi to all,
    @ MOS devs : PuhDerBear or something written to achieve the same goal for MOS is something I REALLY want more than anything else. I know that MOS is developed to be a current modern operating system but the backwards support for legacy Amiga applications is extremely important to me and no doubt most other MOS users. Can I please add my voice to the request for Paula redirection under MOS so that at least the audio applications banging the old hardware chipset can run under MOS.
    I'm in talks with one of the MorphOS Team developer about bounty for that but don't hold your breath. Will keep you updated if anything comes up out of that.
    Any news on this front?
  • »30.04.16 - 23:33
    redrumloa
    Now ~6 months after this post I don't care anymore. Drop 100% of legacy and work on the NG solution. Time to leave legacy and PPC in the dust IMO. If we move to X86-64 we should get a more proper WinUAE port which is sufficient.
  • »01.05.16 - 15:53
    Posts: 874 from 2003/3/4
    I wonder if you remember the trouble we had just getting Ralph to support floppy, 8 bit screens, and WarpOS.
    A Nallehpuh-like solution was given serious consideration but considered not worthwhile. The reasons I heard were:
    - The system is not compatible without major changes (MorphOS doesn't ever support writing to memory without allocating it, whatever the reason, so there's nothing to trap)
    - Most games that it would work for wouldn't run on MorphOS anyway, for other reasons
    - Performance hit would be prohibitive even with hacks
    - The existence of UAE, which was always the better option for running games
    - It wasn't great even on Amithlon.
  • »01.05.16 - 19:50
    IF the legacy software you are concerned with is 68K software.
    I honestly use very few of those packages.
    And while PPC software can be recompiled, rewrites will be necessary for anything relying on the original API.
    Then again, I am really looking forward to the shift.
    Unless someone creates an e6500 based device, there isn't much to look forward to after the X5000.
    And, again, my faith in our developers is unshakable.
    They are talented and make great choices when planning future developments.
  • »18.05.16 - 14:08
