Alchimie 111111
    Posts: 12083 from 2003/5/22
    > Transparent panels and subdocks are the same thing.
    Okay.
    > As for SMBFS, i guess Geit believed i referred to a FUSE-based SMBFS. I refer
    > to the one we already have on MorphOS/AmigaOS, but with large file support.
    Thanks for clarification. So it will be Olsen's Piru-enhanced SMBFS, fine :-)
    > For the rest, even if ICeFS, Helios don't make it for 3.0 release, they're still
    > available separately anyway. :)
    Yes, of course :-)
    So this is the revised list of the mentioned features that will only come after 3.0:
    - R300 3D
    - VBO
    - power management (processor speed, low power GPU mode, disable modem, network, power down HDD)
    - SSHFS
    - IceFS (currently available as 3rd party)
    - AirPort (Extreme?)
    - Helios (currently available as 3rd party)
    - transparent Ambient panels with sub-docks and plugins
  • »14.11.11 - 16:40
    > Personally, its the lack of R300 3D and Airport drivers that disappoints me.
    Disappointment regarding lack of R300 3D drivers is fully understandable, but did you really expect AirPort or even AirPort Extreme support to be in the next MorphOS release? I mean, it was nowhere and nowhen hinted at by the MorphOS Team, so it couldn't be expected to be there. As kind of "workaround" there is always PCMCIA/CardBus in the PowerBook and PCI in the PowerMac.
  • »14.11.11 - 16:56
    Miky060
    Posts: 694 from 2003/2/24
    Jim,
    Mee too.
    [ Edited by Miky060 14.11.2011 - 18:41 ]
  • »14.11.11 - 18:40
    boot_wb
    Posts: 874 from 2007/4/9
    @Jim, Miky060
    Guys, guys! You're just seeing the orange, look at all the green!
    (Although noting that green is only planned for 3.0, not written in stone.)
    Support du PowerBook G4 (modèles 5,6 à 5,9).
    Transferts AGP sur les plateformes le supportant (macs).
    Pilotes WIFI et intégration à la couche TCP/IP : Atheros5000,
    Pilotes SATA et SCSI (Symbios) fonctionnels sur PowerMac G4.
    Pilotes 3D plus rapides,
    Composants systèmes améliorés : MUI, Ambient, Multiview, HDConfig, mount.library, ...
    Nouvelles applications : client FTP/SFTP, logiciel de gravure CD/DVD, nouveau lecteur PDF, éditeur de texte moderne, ...
    Systèmes de fichiers : NTFS3G (écriture), SMBFS (64bits)
    Touchpad et gestures (scrolling, bouton droit, ...).
    Spécificités du clavier (touche Fn, touches de luminosité,...).
    Prise en charge des différentes dalles graphiques (15", 17" et leurs variantes...)
    Port Cardbus (PCMCIA).
    Pilotes WIFI : Atheros5k (via Cardbus), Airport
    Couche WPA/WPA2 (wpa_supplicant) en collaboration avec AROS.
    Surveillance des capteurs : vitesse des ventilateurs, niveau de la batterie, température, ...
    Gestion contrôlée de l'énergie de différents composants en fonction des capteurs et préférences utilisateur (luminosité, rétroéclairage clavier,)
    Pilotes SATA et Symbios fonctionnant sur PowerMac G4
    Transferts AGP (4x, >1Go/s), utile en cas de swap de vram, lecture vidéo, 3D, ...
    Pilotes WIFI Atheros 5k (carte PCI)
    Portage de la couche FUSE, permettant le portage de certains filesystems opensource plus aisément.
    NTFS3g (support écriture)
    SMBFS (64bits)
    Ambient : miniatures vidéo, ...
    MUI : effet de désactivation amélioré, rendu du cadre de l'objet actif configurable, onglets réorganisables, ...
    Multiview : intégration de plus de formats et nouvelles fonctionnalités
    Intégration WPA/WPA2 (wpa_supplicant), indicateurs, configuration, ...
    HDConfig/mount.library : meilleure gestion des tables de partitions mac
    Cairo/Pixman/Fontconfig fournis avec le système
    MagicBeacon : notifications visuelles sur différents types d'évènements (nouveau mail, téléchargement fini, dvd inséré, ...), hautement configurable (contrib ?)
    Grunch : gestionnaire de paquets (contrib ?)
    Jalapeno : logiciel de gravure CD/DVD et création d'ISO, pilotable depuis Ambient, ...
    VPDF : lecteur PDF moderne et compatible, avec vues multiples, basé sur le moteur Poppler.
    Transfer : client FTP et SFTP, vues multiples.
    Scribble : éditeur de texte/sources, basé sur Scintilla. Gestion de projet, autocomplétion, aide contextuelle, colorisation syntaxique pour différents langages,...
    Odyssey Web Browser : synchronisation fréquente avec WebKit, ajout de nouvelles fonctionnalités, ...
    [ Edited by boot_wb 14.11.2011 - 19:13 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »14.11.11 - 20:01
    stephen_robinson
    Posts: 746 from 2007/4/22
    Support the PowerBook G4 (models 5.6 to 5.9).
    AGP transfers on platforms that support it (macs).
    Drivers WiFi and integration with the TCP / IP: Atheros5000,
    Drivers SATA and SCSI (Symbios) functional on PowerMac G4.
    3D drivers faster
    Improved systems components: MUI, Ambient, Multiview, HDConfig, mount.library ...
    New applications: FTP / SFTP, software CD / DVD, new PDF reader, editor Modern ...
    File Systems: NTFS3G (write), SMBFS (64bit)
    And touchpad gestures (scrolling, right ...).
    Specificities of the keyboard (Fn, brightness keys ,...).
    Support for various graphic tiles (15 ", 17" and variations thereof ...)
    Drivers WIFI: Atheros5k (via Cardbus), Airport
    Layer WPA/WPA2 (wpa_supplicant) in collaboration with AROS.
    Sensor monitoring: fan speed, battery level, temperature, ...
    Controlled management of the energy components and sensors based on user preferences (brightness, backlight keyboard)
    Symbios SATA drivers and running on PowerMac G4
    Transfers (AGP 4x,> 1GB / s), useful in case of vram swap, video playback, 3D ...
    Atheros 5k wireless driver (PCI)
    3D drivers faster
    Porting layer FUSE, allowing porting some open source filesystems easier.
    NTFS3g (write support)
    SMBFS (64bit)
    Ambient: miniature video ...
    MUI: effect of disabling improved rendering of part of the active object configurable Arrange tab, ...
    Multiview: integration of more new features and formats
    Integration WPA/WPA2 (wpa_supplicant), indicators, configuration, ...
    HDConfig / mount.library: better management of mac partition tables
    Cairo / Pixman / Fontconfig supplied with the system
    MagicBeacon: visual notifications on different types of events (new mail, download finished, insert dvd, ...), highly configurable (contrib?)
    Grunch: package manager (contrib?)
    Jalapeno: burning software CD / DVD and create ISO, controllable from Ambient, ...
    VPDF: modern and PDF reader compatible with multiple views, based on the engine Poppler.
    Transfer: FTP and SFTP, multiple views.
    Scribble: editor / sources, based on Scintilla. Project management, autocompletion, context-sensitive help, syntax highlighting for different languages, ...
    Odyssey Web Browser: WebKit with frequent synchronization, adding new features, ...
    Well that's good enough for me! Roll on 3.0!
    [ Edited by stephen_robinson 14.11.2011 - 19:56 ]
  • »14.11.11 - 20:55
    Posts: 2720 from 2003/2/24
    @Jim, Miky060
    Personally, I think the Panels/Subdocks is a more pressing matter, something all MorphOS users needs (not just powerbook, like the case with "Airport"), and one of the most prominent and obvious aspects of the GUI, one of the first thing you notice (as a new user) and will want to use. It should be good looking, feature rich, and easy to use!
  • »15.11.11 - 00:19
    No guys,
    I didn't say I expected Airport support, just that lack of it is disappointing.
    Alternatives to that support will have to do.
    And Andreas knows we've been hearing some comments lately that made R300 3D look unlikely.
    So that's no surprise.
    We'll get it (eventually).
    Personally, I don't use wireless internet often (prefering hardwired connections.
    So, as has been said before, this release looks good so far.
  • »15.11.11 - 00:34
    Then we obviously have different definitions of the term "disappointment". I only ever get the feeling I define as disappointment when something I've exptected or seriously hoped for doesn't occur. To my mind there was no reason to expect or seriously hope for AirPort or even AirPort Extreme support in the next MorphOS release as everything the MorphOS Team members have been saying on that matter pointed to it not being included. In fact, I would have considered it a big surprise if it made it there.
    Those were non-public comments made at the same time as public statements to the opposite effect.
    And you're disappointed nonetheless?
  • »15.11.11 - 01:02
    Senex
    Posts: 498 from 2003/2/17
    Nice to see Grunch getting included, hopefully this will yield sufficient support for filling its database.
    Not being obsessed with privacy protection, but just curious, since there had been quite some discussion at amiga-news.de about Grunch in the past:
    Can we expect that when included into MorphOS 3.x the "calling home" option (picture download for installed software found) is disabled by default?
    (Sorry if that's already the case with current v1.28, my MorphOS setup is not up-to-date ATM, this will change with 3.0 release.)
  • »15.11.11 - 05:43
    Miky060
    takemehomegrandma,
    If you don't like Ambient built-in Docks you can always use PolyNet. Me never used Ambient panels, because of their limitations.
  • »15.11.11 - 09:24
    That's exactly what I'm talking about, Ambient's current panels are too limited and AFAIK no visible development has gone into those since MorphOS 1.x or so, and it's not an ideal situation to rely on third party solutions for important parts of your OS IMHO (like when we had to use third party TCP/IP stacks, etc). In MorphOS, you don't have to download AHI, MUI, CGX, Poseidon, etc. It's included and integrated. It's there when you boot the install CD for the first time. It makes the OS complete! :-)
  • »15.11.11 - 09:31
    thefab
    Posts: 92 from 2003/8/19
    hello,
    looking at the updated 3d drivers, is there a huge gap in performance between a 9000pro and a 9800 pro ?
  • »15.11.11 - 15:29
    Crumb
    Posts: 730 from 2003/2/24
    @takemehomegrandma
    I'm not much interested in panels&amidocks, I think an sBar launcher may be enough for me and would integrate better wiht the OS.
    I prefer toolsdaemon-like personalized menus as these are faster and make more sense on MorphOS /AmigaOS.
  • »14.12.11 - 15:26
    Posts: 1032 from 2004/9/23
    Crumb,
    Then you may just need MMKeyboard or Meridian, which both support a pop down start menu.
    Geit
  • »14.12.11 - 17:51
    According to a recent statement from the author, Grunch (and MagicBeacon) won't be included in MorphOS 3.0:
    http://www.pegasosforum.de/viewtopic.php?p=49613#p49613
  • »24.04.12 - 13:06
    magnetic
    Posts: 2129 from 2003/3/1
    For the rest, even if ICeFS, Helios don't make it for 3.0 release, they're still available separately anyway. :)
    Fab
    Why is it so difficult to integrate a File System and a FW stack into the operating system?
    3.0 is taking a lot longer than expected but looks to be the best release since 2.x
  • »25.05.12 - 11:36
    SoundSquare
    Posts: 1213 from 2004/12/1
    Fab
    i suppose they don't fit the quality standard yet.
  • »25.05.12 - 11:59
