Posts: 2033 from 2003/2/24
Yasu wrote:
Thanks. The program confuse me though. I'm trying to go to the BBS SUGA via suga.se, port 42512. How do I do that?
Should be simple... but maybe you're stuck somewhere else :) Anyway if the program is running as it should, it's this simple:
If you just want to make an occasional call, click "Connect" button and type "suga.se,42512" and click "Ok". Here's a
screenshot.
And for future use it's of course better to add to address book.. click "Address" and "Add" and type info like seen in this another
screenshot. Then you can double click it from the address list to connect and use pulldown menu to send login/password if you defined them too.
For further configuration you should see some entries in the Settings pulldown menu.. for example Transfer Protocol to xprzmodem.library if you want to up/download files.
[ Edited by jPV 03.11.2015 - 20:35 ]
